주요 콘텐츠로 건너뛰기
Dell Inspiron n5050 Hard Drive Replacement
필요한 것
  1. Dell Inspiron n5050 Hard Drive Replacement, Battery: 1 단계, 이미지 1/1
    • Flip your laptop over to view the bottom and locate the two locks.
  2. Dell Inspiron n5050 Hard Drive Replacement: 2 단계, 이미지 1/1
    • Slide the two locks away from each other.
    • Sliding these locks will loosen the battery to allow removal.
  3. Dell Inspiron n5050 Hard Drive Replacement: 3 단계, 이미지 1/2 Dell Inspiron n5050 Hard Drive Replacement: 3 단계, 이미지 2/2
    • Pull battery out of the laptop.
    • Your laptop's battery should be completely removed.
  4. Dell Inspiron n5050 Hard Drive Replacement, Keyboard: 4 단계, 이미지 1/2 Dell Inspiron n5050 Hard Drive Replacement, Keyboard: 4 단계, 이미지 2/2
    • Flip the laptop right side up. Open the laptop.
    • Gently press in the four retaining tabs along the top of the keyboard with a spudger, one at a time.
    • After the first tab is released, gently lift up on the keyboard so it doesn't lock again. Finish the other three tabs while gently lifting up on the keyboard. The keyboard will hinge up along the bottom.
  5. Dell Inspiron n5050 Hard Drive Replacement: 5 단계, 이미지 1/3 Dell Inspiron n5050 Hard Drive Replacement: 5 단계, 이미지 2/3 Dell Inspiron n5050 Hard Drive Replacement: 5 단계, 이미지 3/3
    • Gently flip the data cable latch away from the data cable with flat side of spudger.
    • Lift the cable up and out.
    • When reinstalling cable, there are two retainer wings on the sides of the cable that the cable that lock onto the bottom of the cable latch area. When these are in place the cable is properly inserted.
    • For removing the optical drive you don't need to disconnect the keyboard ribbon cable.
  6. Dell Inspiron n5050 Hard Drive Replacement, Upper Case: 6 단계, 이미지 1/1
    • Close the lid, flip the laptop bottom side up with the battery at the top.
    • Remove the 11 screws holding the upper case to the lower case.
  7. Dell Inspiron n5050 Hard Drive Replacement: 7 단계, 이미지 1/1
    • Flip the laptop over and open the lid.
    • Remove the two screws from the upper case.
  8. Dell Inspiron n5050 Hard Drive Replacement: 8 단계, 이미지 1/3 Dell Inspiron n5050 Hard Drive Replacement: 8 단계, 이미지 2/3 Dell Inspiron n5050 Hard Drive Replacement: 8 단계, 이미지 3/3
    • Gently unplug the power cable.
    • You lift up on the dark gray latch.
    • Pull the blue ribbon up.
    • Gently unplug the touchpad cable.
    • Lift up on the dark gray latch.
  9. Dell Inspiron n5050 Hard Drive Replacement: 9 단계, 이미지 1/1
    • Grab the metal frame of the upper case and gently pull it away from the lower case. Disconnect the cable that says MB before removing the palmrest.
    • Work your way around the perimeter of the upper case.
결론
다른 42명이 해당 안내서를 완성하였습니다.
Tyler
회원 가입일: 06/19/12
4,968 평판
안내서 16개 작성하였습니다
TechForce TechForce 회원
Business
2 회원들
안내서 25개 작성하였습니다
댓글 10개
Awesome guide! Thank you so much for posting this.
Chris Baines - 답글
My issue was that hard drive slipped out of it connector. Snapped it back in. Works! Thanks for great instructions.
Joe B - 답글
Thanks for your help - now reformattting in a different laptop
rosen220462 - 답글
I've replaced my drive as described above.
Can anyone tell me what comes next?
*I turned it on, got dialog on the drive recognized, but I couldn't get it started.
I did try the dell drivers & utilities that came with it with no luck.
I looked into the options under F2, F8 & F12.
No luck there.
I'm still digging through e-how links.
Sage - 답글
A new hard drive normally doesn't have Windows installed on it. Hopefully you have created the dell recovery dvds when you first obtained the laptop. If you don't have that you can try and download the dvd image from Microsoft at http://www.microsoft.com/en-us/software-....
Tyler -
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 17
30일 전: 42
전체 시간: 66,538
