주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
소개
The keyboard needs to be removed to access everything (hard drive, optical drive, RAM, motherboard).
  1. Flip your laptop over to view the bottom and locate the two locks.
    • Flip your laptop over to view the bottom and locate the two locks.
  2. Slide the two locks away from each other.
    • Slide the two locks away from each other.
    • Sliding these locks will loosen the battery to allow removal.
  3. Pull battery out of the laptop. Your laptop's battery should be completely removed.
    • Pull battery out of the laptop.
    • Your laptop's battery should be completely removed.
  4. Flip the laptop right side up.  Open the laptop. Gently press in the four retaining tabs along the top of the keyboard with a spudger, one at a time.
    • Flip the laptop right side up. Open the laptop.
    • Gently press in the four retaining tabs along the top of the keyboard with a spudger, one at a time.
    • After the first tab is released, gently lift up on the keyboard so it doesn't lock again. Finish the other three tabs while gently lifting up on the keyboard. The keyboard will hinge up along the bottom.
  5. Gently flip the data cable latch away from the data cable with flat side of spudger. Lift the cable up and out. When reinstalling cable, there are two retainer wings on the sides of the cable that the cable that lock onto the bottom of the cable latch area.  When these are in place the cable is properly inserted.
    • Gently flip the data cable latch away from the data cable with flat side of spudger.
    • Lift the cable up and out.
    • When reinstalling cable, there are two retainer wings on the sides of the cable that the cable that lock onto the bottom of the cable latch area. When these are in place the cable is properly inserted.
    • For removing the optical drive you don't need to disconnect the keyboard ribbon cable.
    What do I do is i broke the cable retainer wings and the black thing?
    Wezley Joao Ferreira - 답글
    If the connector on the motherboard is still attached and only the clip is broken you can try and find a new clip, or perhaps tape the keyboard in place with electrical tape.
    Tyler - 답글
    I didn’t need to disconnect and remove the cable. I simply set the keyboard gently to the side. This gave me full access to the two RAM module slots for replacement. Hopefully this will make the procedure easier.
    Clemmitt Sigler - 답글
결론
다른 4명이 해당 안내서를 완성하였습니다.
Tyler
회원 가입일: 2012년 06월 19일
4,689 평판
안내서 16개 작성하였습니다
TechForce TechForce 회원
Business
2 회원들
안내서 18개 작성하였습니다
dis has realy helped me sir... love you!
jovialcom - 답글
Dell Inspiron 15 - M5040 N5040 N5050 disassembly
https://youtu.be/3c5P0pJgckg
mohamed - 답글
Here’s a video guide to replacing the keyboard on this (or similar) laptop: https://www.youtube.com/watch?v=6T3xgkC-...
Paul Freeman-Powell - 답글
My keyboard is not have a clips what i do?
BurIsm - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 44
전체 시간: 8,956
