주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
소개
The optical drive is held in by a single screw. This guide will help you get to that screw and slide the optical drive out of its bay.
부품
지정된 부품이 없습니다.
  1. Flip your laptop over to view the bottom and locate the two locks.
    • Flip your laptop over to view the bottom and locate the two locks.
  2. Slide the two locks away from each other.
    • Slide the two locks away from each other.
    • Sliding these locks will loosen the battery to allow removal.
  3. Pull battery out of the laptop. Your laptop's battery should be completely removed.
    • Pull battery out of the laptop.
    • Your laptop's battery should be completely removed.
  4. Flip the laptop right side up.  Open the laptop. Gently press in the four retaining tabs along the top of the keyboard with a spudger, one at a time.
    • Flip the laptop right side up. Open the laptop.
    • Gently press in the four retaining tabs along the top of the keyboard with a spudger, one at a time.
    • After the first tab is released, gently lift up on the keyboard so it doesn't lock again. Finish the other three tabs while gently lifting up on the keyboard. The keyboard will hinge up along the bottom.
  5. Gently flip the data cable latch away from the data cable with flat side of spudger. Lift the cable up and out. When reinstalling cable, there are two retainer wings on the sides of the cable that the cable that lock onto the bottom of the cable latch area.  When these are in place the cable is properly inserted.
    • Gently flip the data cable latch away from the data cable with flat side of spudger.
    • Lift the cable up and out.
    • When reinstalling cable, there are two retainer wings on the sides of the cable that the cable that lock onto the bottom of the cable latch area. When these are in place the cable is properly inserted.
    • For removing the optical drive you don't need to disconnect the keyboard ribbon cable.
  6. Unscrew the screw next to the wireless card. Unscrew the screw next to the wireless card.
    • Unscrew the screw next to the wireless card.
  7. Stand laptop on its side.
    • Stand laptop on its side.
    • Use the flat end of the spudger to unseat the optical drive.
    • It works best with a twisting motion of the spudger.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Tyler
회원 가입일: 2012년 06월 19일
4,689 평판
안내서 16개 작성하였습니다
TechForce TechForce 회원
Business
2 회원들
안내서 18개 작성하였습니다
I am curious why the guide notes that you need to remove the keyboard ribbon? Removing and installing that cable weakens it and could damage it. I was able to remove the drive without taking out the ribbon cable; I just flipped the keyboard out of the way.
afterhourspc - 답글
it says you don’t need
F2w -
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 8
전체 시간: 3,066
