주요 콘텐츠로 건너뛰기
Dell Inspiron n5110 heat sink and thermal paste replacement
필요한 것
동영상 개요
  1. Dell Inspiron n5110 heat sink and thermal paste replacement, Heat Sink System Cleaning / Thermal Paste Replacing: 1 단계, 이미지 1/3 Dell Inspiron n5110 heat sink and thermal paste replacement, Heat Sink System Cleaning / Thermal Paste Replacing: 1 단계, 이미지 2/3 Dell Inspiron n5110 heat sink and thermal paste replacement, Heat Sink System Cleaning / Thermal Paste Replacing: 1 단계, 이미지 3/3
    • Switch-off the laptop and remove the battery.
    • To remove the keyboard lift it from one side by using cutter. Now open 4x locking clips at the upper side on the keyboard.
  2. Dell Inspiron n5110 heat sink and thermal paste replacement: 2 단계, 이미지 1/3 Dell Inspiron n5110 heat sink and thermal paste replacement: 2 단계, 이미지 2/3 Dell Inspiron n5110 heat sink and thermal paste replacement: 2 단계, 이미지 3/3
    • Open the keyboard flex cable connector and remove the KB.
    • Open the RAM memory cover.
    • The DVD drive is held by one screw. After unscrewing, you can remove the drive.
  3. Dell Inspiron n5110 heat sink and thermal paste replacement: 3 단계, 이미지 1/3 Dell Inspiron n5110 heat sink and thermal paste replacement: 3 단계, 이미지 2/3 Dell Inspiron n5110 heat sink and thermal paste replacement: 3 단계, 이미지 3/3
    • 12x screws M 2,5x5,0
    • 4x screws M 2,5x5,0
    • Power switch cable connector
    • Mouse pad cable connector
    • Hot keys cable connector
    • After removing all the screws and opening all the connectors, you can remove the upper case.
  4. Dell Inspiron n5110 heat sink and thermal paste replacement: 4 단계, 이미지 1/3 Dell Inspiron n5110 heat sink and thermal paste replacement: 4 단계, 이미지 2/3 Dell Inspiron n5110 heat sink and thermal paste replacement: 4 단계, 이미지 3/3
    • Eject the Card Reader Blanking Plate.
    • Disconnect the LCD display flex cable.
    • Disconnect the WiFi and Bluetooth coaxial cables.
    • The LCD display hings are held by 4x M 2,5x5.0 screws.
    • Now you can remove the LCD display module.
  5. Dell Inspiron n5110 heat sink and thermal paste replacement: 5 단계, 이미지 1/3 Dell Inspiron n5110 heat sink and thermal paste replacement: 5 단계, 이미지 2/3 Dell Inspiron n5110 heat sink and thermal paste replacement: 5 단계, 이미지 3/3
    • Unscrew 5x M2.5x5.0 screws.
    • Disconnect the Loudspeakers cable connector.
    • Remove the Daughter Bluetooth board.
    • Start removing the mother board by lifting from the right side (near to the DVD drive connector).
    • Be careful, there are connectors between mother board and another two additional small boards (charging port board and USB connectors, WiFi card slot board).
  6. Dell Inspiron n5110 heat sink and thermal paste replacement: 6 단계, 이미지 1/3 Dell Inspiron n5110 heat sink and thermal paste replacement: 6 단계, 이미지 2/3 Dell Inspiron n5110 heat sink and thermal paste replacement: 6 단계, 이미지 3/3
    • Remove the Hard Disk drive.
    • Disconnect the Fan cable connector.
  7. Dell Inspiron n5110 heat sink and thermal paste replacement: 7 단계, 이미지 1/3 Dell Inspiron n5110 heat sink and thermal paste replacement: 7 단계, 이미지 2/3 Dell Inspiron n5110 heat sink and thermal paste replacement: 7 단계, 이미지 3/3
    • Remove the Heat Sink system.
    • Clean the cooper contact surface.
  8. Dell Inspiron n5110 heat sink and thermal paste replacement: 8 단계, 이미지 1/3 Dell Inspiron n5110 heat sink and thermal paste replacement: 8 단계, 이미지 2/3 Dell Inspiron n5110 heat sink and thermal paste replacement: 8 단계, 이미지 3/3
    • Disassemble the Heat Sink system to clean the fan and the radiator from inside.
  9. Dell Inspiron n5110 heat sink and thermal paste replacement: 9 단계, 이미지 1/2 Dell Inspiron n5110 heat sink and thermal paste replacement: 9 단계, 이미지 2/2
    • Clean the old thermal paste / compose from the CPU.
  10. Dell Inspiron n5110 heat sink and thermal paste replacement: 10 단계, 이미지 1/3 Dell Inspiron n5110 heat sink and thermal paste replacement: 10 단계, 이미지 2/3 Dell Inspiron n5110 heat sink and thermal paste replacement: 10 단계, 이미지 3/3
결론
다른 18명이 해당 안내서를 완성하였습니다.
ZFix
회원 가입일: 12/09/13
191,278 평판
안내서 330개 작성하였습니다
Master Techs Master Techs 회원
Community
322 회원들
안내서 2,532개 작성하였습니다
댓글 2개
Which thermal paste would you recommend?
PinupSquid - 답글
Done! It works, now my laptop is as new!
alexmogavero - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 37
전체 시간: 22,124
