주요 콘텐츠로 건너뛰기
Dell Latitude 10-ST2e Battery Replacement
필요한 것
  1. Dell Latitude 10-ST2e Battery Replacement, Battery: 1 단계, 이미지 1/3 Dell Latitude 10-ST2e Battery Replacement, Battery: 1 단계, 이미지 2/3 Dell Latitude 10-ST2e Battery Replacement, Battery: 1 단계, 이미지 3/3
    • Place tablet face-down on flat surface.
    • Using the blue opening tool, separate the back plastic cover from the device. Start in a corner, and work your way around the tablet.
  2. Dell Latitude 10-ST2e Battery Replacement: 2 단계, 이미지 1/2 Dell Latitude 10-ST2e Battery Replacement: 2 단계, 이미지 2/2
    • Remove the four 7.0mm screws securing the battery with a JIS #00 screwdriver.
  3. Dell Latitude 10-ST2e Battery Replacement: 3 단계, 이미지 1/2 Dell Latitude 10-ST2e Battery Replacement: 3 단계, 이미지 2/2
    • With the blue opening tool, gently lift up and remove the battery from the tablet.
    • Do not damage, puncture, cut, or bend the battery, as this may cause bodily harm.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Vincent Hoffman
회원 가입일: 09/25/17
261 평판
안내서 2개 작성하였습니다
USF Tampa, Team S16-G4, Eyestone Fall 2017 USF Tampa, Team S16-G4, Eyestone Fall 2017 회원
USFT-EYESTONE-F17S16G4
4 회원들
안내서 13개 작성하였습니다
댓글 한 개
I found that the down volume control was jammed by the case. So be careful with the reassembly around the volume control.
James Smith - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 13
전체 시간: 2,407
