주요 콘텐츠로 건너뛰기
Dell Latitude 10-ST2e Front Facing Camera Replacement
필요한 것
  1. Dell Latitude 10-ST2e Front Facing Camera Replacement, Front Facing Camera: 1 단계, 이미지 1/3 Dell Latitude 10-ST2e Front Facing Camera Replacement, Front Facing Camera: 1 단계, 이미지 2/3 Dell Latitude 10-ST2e Front Facing Camera Replacement, Front Facing Camera: 1 단계, 이미지 3/3
    • Using the blue opening tool, separate the back plastic cover from the device. Start in a corner, and work your way around the tablet.
  2. Dell Latitude 10-ST2e Front Facing Camera Replacement: 2 단계, 이미지 1/2 Dell Latitude 10-ST2e Front Facing Camera Replacement: 2 단계, 이미지 2/2
    • Using a JIS #00 screwdriver, remove the one 4.0mm screw securing the camera to the motherboard.
  3. Dell Latitude 10-ST2e Front Facing Camera Replacement: 3 단계, 이미지 1/2 Dell Latitude 10-ST2e Front Facing Camera Replacement: 3 단계, 이미지 2/2
    • Use an opening tool to release the black clamp. With the tweezers gently lift and disconnect the motherboad from the camera.
  4. Dell Latitude 10-ST2e Front Facing Camera Replacement: 4 단계, 이미지 1/2 Dell Latitude 10-ST2e Front Facing Camera Replacement: 4 단계, 이미지 2/2
    • Gently lift up the camera using the plastic opening tool and remove it from the tablet.
결론
Khawja
회원 가입일: 09/25/17
258 평판
안내서 2개 작성하였습니다
USF Tampa, Team S16-G4, Eyestone Fall 2017 USF Tampa, Team S16-G4, Eyestone Fall 2017 회원
USFT-EYESTONE-F17S16G4
4 회원들
안내서 13개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 212
