주요 콘텐츠로 건너뛰기
Dell Latitude 10-ST2e Motherboard Replacement
필요한 것
  1. Dell Latitude 10-ST2e Motherboard Replacement, Motherboard: 1 단계, 이미지 1/3 Dell Latitude 10-ST2e Motherboard Replacement, Motherboard: 1 단계, 이미지 2/3 Dell Latitude 10-ST2e Motherboard Replacement, Motherboard: 1 단계, 이미지 3/3
    • Using the blue opening tool, separate the back plastic cover from the device. Start in a corner, and work your way around the tablet.
  2. Dell Latitude 10-ST2e Motherboard Replacement: 2 단계, 이미지 1/2 Dell Latitude 10-ST2e Motherboard Replacement: 2 단계, 이미지 2/2
    • Remove the four 4.0mm black screws on the perimeter of the device using a JIS #00 screwdriver
  3. Dell Latitude 10-ST2e Motherboard Replacement: 3 단계, 이미지 1/2 Dell Latitude 10-ST2e Motherboard Replacement: 3 단계, 이미지 2/2
    • Remove the two 4.0mm silver screws using the JIS #00 screwdriver.
  4. Dell Latitude 10-ST2e Motherboard Replacement: 4 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Disconnect the connection of the front camera clamp by releasing the clamp with tweezers.
    • Pull up on the connection from the motherboard.
    • Avoid damaging the connection.
  5. Dell Latitude 10-ST2e Motherboard Replacement: 5 단계, 이미지 1/3 Dell Latitude 10-ST2e Motherboard Replacement: 5 단계, 이미지 2/3 Dell Latitude 10-ST2e Motherboard Replacement: 5 단계, 이미지 3/3
    • Using an opening tool, lift upwards on the white clamp, and pull the blue tab out of the connection with tweezers.
  6. Dell Latitude 10-ST2e Motherboard Replacement: 6 단계, 이미지 1/2 Dell Latitude 10-ST2e Motherboard Replacement: 6 단계, 이미지 2/2
    • Using tweezers, disconnect the white and black wires from the bottom of the motherboard.
    • Pull upwards while holding the brass connections. Do not pull on the wires.
  7. Dell Latitude 10-ST2e Motherboard Replacement: 7 단계, 이미지 1/3 Dell Latitude 10-ST2e Motherboard Replacement: 7 단계, 이미지 2/3 Dell Latitude 10-ST2e Motherboard Replacement: 7 단계, 이미지 3/3
    • Disconnect the two clamps, one orange and one white, using tweezers next to the battery.
  8. Dell Latitude 10-ST2e Motherboard Replacement: 8 단계, 이미지 1/1
    • Remove the four 7.0mm screws securing the battery with a JIS #00 screwdriver.
  9. Dell Latitude 10-ST2e Motherboard Replacement: 9 단계, 이미지 1/2 Dell Latitude 10-ST2e Motherboard Replacement: 9 단계, 이미지 2/2
    • With the blue opening tool, gently lift up and remove the battery from the tablet.
    • Do not damage, puncture, cut, or bend the battery, as this may cause bodily harm.
  10. Dell Latitude 10-ST2e Motherboard Replacement: 10 단계, 이미지 1/3 Dell Latitude 10-ST2e Motherboard Replacement: 10 단계, 이미지 2/3 Dell Latitude 10-ST2e Motherboard Replacement: 10 단계, 이미지 3/3
    • Rotate the motherboard upwards from the tablet using tweezers, but do not remove completely from the device. As you lift, disconnect the black and red wire located underneath the motherboard before removing it completely from the tablet.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Vincent Hoffman
회원 가입일: 09/25/17
261 평판
안내서 2개 작성하였습니다
USF Tampa, Team S16-G4, Eyestone Fall 2017 USF Tampa, Team S16-G4, Eyestone Fall 2017 회원
USFT-EYESTONE-F17S16G4
4 회원들
안내서 13개 작성하였습니다
댓글 한 개
thanks, very usefull……….question: where is the NVram?
kintaroe69 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 13
전체 시간: 1,372
