소개
We're going teach you how to remove the rear facing camera from the Dell Latitude 10-ST2e.
필요한 것
Using the blue opening tool, separate the back plastic cover from the device. Start in a corner, and work your way around the tablet.
Once the motherboard is removed, place on a flat surface facing down. Use the plastic opening tool to disconnect and remove the camera from the motherboard.
다른 한 분이 해당 안내서를 완성하였습니다.
