주요 콘텐츠로 건너뛰기
Dell Latitude 10-ST2e Speaker Replacement
필요한 것
  1. Dell Latitude 10-ST2e Speaker Replacement, Speaker: 1 단계, 이미지 1/3 Dell Latitude 10-ST2e Speaker Replacement, Speaker: 1 단계, 이미지 2/3 Dell Latitude 10-ST2e Speaker Replacement, Speaker: 1 단계, 이미지 3/3
    • Place tablet face-down on flat surface
    • Using the blue opening tool to separate the back plastic cover from the device. Start in a corner, and work your way around the tablet.
  2. Dell Latitude 10-ST2e Speaker Replacement: 2 단계, 이미지 1/3 Dell Latitude 10-ST2e Speaker Replacement: 2 단계, 이미지 2/3 Dell Latitude 10-ST2e Speaker Replacement: 2 단계, 이미지 3/3
    • Using aJIS #00 screwdriver locate and remove the two 3.5mm screws by the plastic covers on left and right side of the tablet
  3. Dell Latitude 10-ST2e Speaker Replacement: 3 단계, 이미지 1/2 Dell Latitude 10-ST2e Speaker Replacement: 3 단계, 이미지 2/2
    • Using the blue opening tool to gently remove the wire connecting the speaker to motherboard
  4. Dell Latitude 10-ST2e Speaker Replacement: 4 단계, 이미지 1/2 Dell Latitude 10-ST2e Speaker Replacement: 4 단계, 이미지 2/2
    • Use the blue opening tool to lift up the speaker counterclockwise from the corner. As you lift up, the speaker will release from the casing. Repeat this process for the second speaker.
  5. Dell Latitude 10-ST2e Speaker Replacement: 5 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Use tweezers to help lift the white and blue wires connecting both speakers.
  6. Dell Latitude 10-ST2e Speaker Replacement: 6 단계, 이미지 1/2 Dell Latitude 10-ST2e Speaker Replacement: 6 단계, 이미지 2/2
    • Grab both speakers and gently lift up to remove them from the tablet.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Bradley Fritz
회원 가입일: 09/25/17
206 평판
안내서 1개 작성함
USF Tampa, Team S16-G4, Eyestone Fall 2017 USF Tampa, Team S16-G4, Eyestone Fall 2017 회원
USFT-EYESTONE-F17S16G4
4 회원들
안내서 13개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 251
