소개
If your Dell Latitude 3190 laptop is losing power after a short amount of time after being unplugged, use this guide to replace the battery of the laptop.
The battery of a laptop allows the user to store power in the laptop for a certain amount of time while not having to be connected to an external power source such as an outlet in order for the laptop to work.
The laptop’s battery needs to be replaced when the battery is not powering the laptop very long before needing to be plugged in.
Before beginning this guide, be sure to power off your device and unplug it from the charging cable.
필요한 것
Use a Phillips #0 screwdriver to remove the seven 7 mm screws securing the back case.
