주요 콘텐츠로 건너뛰기
Dell Latitude 3190 Power Switch Board Replacement
필요한 것
  1. Dell Latitude 3190 Power Switch Board Replacement, Base Cover: 1 단계, 이미지 1/2 Dell Latitude 3190 Power Switch Board Replacement, Base Cover: 1 단계, 이미지 2/2
    • Use a Phillips #0 screwdriver to remove the seven 7 mm screws securing the back case.
  2. Dell Latitude 3190 Power Switch Board Replacement: 2 단계, 이미지 1/3 Dell Latitude 3190 Power Switch Board Replacement: 2 단계, 이미지 2/3 Dell Latitude 3190 Power Switch Board Replacement: 2 단계, 이미지 3/3
    • Using a plastic opening tool carefully separate the plastic base cover from the rest of the laptop.
    • Lift the bottom cover from the laptop.
  3. Dell Latitude 3190 Power Switch Board Replacement, Battery: 3 단계, 이미지 1/1
    • Locate the battery.
  4. Dell Latitude 3190 Power Switch Board Replacement: 4 단계, 이미지 1/3 Dell Latitude 3190 Power Switch Board Replacement: 4 단계, 이미지 2/3 Dell Latitude 3190 Power Switch Board Replacement: 4 단계, 이미지 3/3
    • Disconnect the battery cable located on the top of the battery.
    • Use the spudger and disconnect the battery cable.
    • Pull the cable out of the way.
  5. Dell Latitude 3190 Power Switch Board Replacement: 5 단계, 이미지 1/3 Dell Latitude 3190 Power Switch Board Replacement: 5 단계, 이미지 2/3 Dell Latitude 3190 Power Switch Board Replacement: 5 단계, 이미지 3/3
    • Use a Phillips #0 screwdriver to remove the three 3 mm screws from the battery.
  6. Dell Latitude 3190 Power Switch Board Replacement: 6 단계, 이미지 1/3 Dell Latitude 3190 Power Switch Board Replacement: 6 단계, 이미지 2/3 Dell Latitude 3190 Power Switch Board Replacement: 6 단계, 이미지 3/3
    • Pull the black battery tap upwards to remove the battery.
    • The battery adhesive is strong, do not be afraid to use force. You may need to use the spudger or opening tool as a wedge.
  7. Dell Latitude 3190 Power Switch Board Replacement, Power Switch Board: 7 단계, 이미지 1/2 Dell Latitude 3190 Power Switch Board Replacement, Power Switch Board: 7 단계, 이미지 2/2
    • Disconnect the power switch cable from the motherboard.
  8. Dell Latitude 3190 Power Switch Board Replacement: 8 단계, 이미지 1/3 Dell Latitude 3190 Power Switch Board Replacement: 8 단계, 이미지 2/3 Dell Latitude 3190 Power Switch Board Replacement: 8 단계, 이미지 3/3
    • Remove the two 3 mm screws that secure the power switch board on the computer.
  9. Dell Latitude 3190 Power Switch Board Replacement: 9 단계, 이미지 1/2 Dell Latitude 3190 Power Switch Board Replacement: 9 단계, 이미지 2/2
    • Lift the power switchboard away from the computer.
결론
Haley Smith
회원 가입일: 09/01/21
305 평판
안내서 2개 작성하였습니다
Gateway, Team 1-5, Saknee Fall 2021 Gateway, Team 1-5, Saknee Fall 2021 회원
GCC-SAKNEE-F21S1G5
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 22
전체 시간: 392
