소개
In this guide, we will be showing you how to replace the fan setup within the Dell Latitude 3380.
The fan is an important part of the laptop as it helps keep all the parts cool which prevents overheating. When a part is overheated, it will not perform as well as it should.
필요한 것
Turn the laptop over so that the back is facing up.
Remove the nine 3 mm screws with a Phillips #0 screwdriver.
거의 끝나갑니다!
결론
