소개
You may want to remove the system fan because it has failed, or just for a cleaning.
Disconnect the battery cable from the motherboard.
Remove the 4 screws holding it in place
Battery can now be removed from device.
Unplug the fan header
Unplug the VGA board cable
Unplug the LCD cable
Once these 2 screws are removed the fan will lift out as long as the cables are out of the way.
다른 한 분이 해당 안내서를 완성하였습니다.
