주요 콘텐츠로 건너뛰기
Dell Latitude 3500 VGA Board Replacement
필요한 것
  1. Dell Latitude 3500 VGA Board Replacement, Remove screws: 1 단계, 이미지 1/1
    • 10 screws hold the bottom cover in place -- these stay in the bottom cover.
  2. Dell Latitude 3500 VGA Board Replacement, Separate bottom cover and palmrest: 2 단계, 이미지 1/1
    • Using a spudger will make quick work of this step.
  3. Dell Latitude 3500 VGA Board Replacement, Disconnect and Remove Battery: 3 단계, 이미지 1/1
    • Disconnect the battery cable from the motherboard.
    • Remove the 4 screws holding it in place
    • Battery can now be removed from device.
  4. Dell Latitude 3500 VGA Board Replacement, Disconnect Surrounding Connections from System Fan: 4 단계, 이미지 1/1
    • Unplug the fan header
    • Unplug the VGA board cable
    • Unplug the LCD cable
  5. Dell Latitude 3500 VGA Board Replacement, Remove Fan Screws: 5 단계, 이미지 1/1
    • Once these 2 screws are removed the fan will lift out as long as the cables are out of the way.
  6. Dell Latitude 3500 VGA Board Replacement, Disconnect VGA Board: 6 단계, 이미지 1/1
    • Pull straight up from the motherboard
  7. Dell Latitude 3500 VGA Board Replacement, Remove Screws: 7 단계, 이미지 1/1
    • 2 screws
    • Board can now be safely removed from device
결론
Jake
회원 가입일: 03/08/23
1,300 평판
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 34
