주요 콘텐츠로 건너뛰기
Dell Latitude 3520 System Fan Replacement
필요한 것
  1. Dell Latitude 3520 System Fan Replacement, Remove MicroSD-card: 1 단계, 이미지 1/1
    • Push the microSD-card to eject it from the slot.
    • Remove the microSD-card from the computer.
  2. Dell Latitude 3520 System Fan Replacement, Bottom Case: 2 단계, 이미지 1/3 Dell Latitude 3520 System Fan Replacement, Bottom Case: 2 단계, 이미지 2/3 Dell Latitude 3520 System Fan Replacement, Bottom Case: 2 단계, 이미지 3/3
    • Loosen the nine screws 2mm Phillips #0 that secure the base cover to the assembly.
    • Using a plastic scribe, pry open the base cover starting from the recesses located in the indents near the hinges at the top edge of the base cover.
    • Carefully lift and remove the base cover.
  3. Dell Latitude 3520 System Fan Replacement, Battery: 3 단계, 이미지 1/1
    • Slide the metal above the connector on the battery to unlock.
  4. Dell Latitude 3520 System Fan Replacement: 4 단계, 이미지 1/2 Dell Latitude 3520 System Fan Replacement: 4 단계, 이미지 2/2
    • Peel the adhesive tapes and the battery cable.
  5. Dell Latitude 3520 System Fan Replacement: 5 단계, 이미지 1/1
    • Disconnect the battery cable from the connector on the system board.
  6. Dell Latitude 3520 System Fan Replacement: 6 단계, 이미지 1/2 Dell Latitude 3520 System Fan Replacement: 6 단계, 이미지 2/2
    • Remove the three 2mm Phillip #0 screws that secure the battery in place.
  7. Dell Latitude 3520 System Fan Replacement: 7 단계, 이미지 1/1
    • Lift and remove the battery.
  8. Dell Latitude 3520 System Fan Replacement, System Fan: 8 단계, 이미지 1/1
    • Disconnect the system fan cable from the connector on the system board.
  9. Dell Latitude 3520 System Fan Replacement: 9 단계, 이미지 1/1
    • Remove the two 2mm Phillips #0 screws that secure the system fan.
  10. Dell Latitude 3520 System Fan Replacement: 10 단계, 이미지 1/1
    • Lift and remove the system fan.
결론
Shawn Smith
회원 가입일: 09/08/23
871 평판
안내서 7개 작성하였습니다
University of New Orleans, Team 4-2, McDonald Fall 2023 University of New Orleans, Team 4-2, McDonald Fall 2023 회원
UNO-MCDONALD-F23S4G2
4 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 16
전체 시간: 117
