주요 콘텐츠로 건너뛰기
Dell Latitude 5401 RAM Replacement
필요한 것
  1. Dell Latitude 5401 RAM Replacement, RAM: 1 단계, 이미지 1/2 Dell Latitude 5401 RAM Replacement, RAM: 1 단계, 이미지 2/2
    • Disconnect any devices plugged into the computer.
    • Hold the power button down for 5-10 seconds to shutdown the laptop.
    • Note that during installation or removal of any hardware ensure all data has been backed up properly.
  2. Dell Latitude 5401 RAM Replacement: 2 단계, 이미지 1/2 Dell Latitude 5401 RAM Replacement: 2 단계, 이미지 2/2
    • Flip the laptop so the bottom is facing up.
    • Use a small Phillips screwdriver to loosen the eight screws on the back case.
    • The screws are captive and will remain attached loosely to the lower case.
  3. Dell Latitude 5401 RAM Replacement: 3 단계, 이미지 1/3 Dell Latitude 5401 RAM Replacement: 3 단계, 이미지 2/3 Dell Latitude 5401 RAM Replacement: 3 단계, 이미지 3/3
    이 단계에 사용된 도구:
    Plastic Cards
    $2.99
    구매
    • Expose the seam that connects the laptop case by pulling on a corner screw while holding the base.
    • Insert a plastic card into the gap.
    • Slide the card around the perimeter of the case to release the clips.
    • Gently pry the laptop apart.
    • This step can be difficult and will take some time and strength!
  4. Dell Latitude 5401 RAM Replacement: 4 단계, 이미지 1/3 Dell Latitude 5401 RAM Replacement: 4 단계, 이미지 2/3 Dell Latitude 5401 RAM Replacement: 4 단계, 이미지 3/3
    • Use a small Phillips screwdriver to loosen the two screws securing the battery.
    • These screws are captive and should not be removed.
    • If the battery is swollen, be very careful and follow these safety suggestions.
  5. Dell Latitude 5401 RAM Replacement: 5 단계, 이미지 1/2 Dell Latitude 5401 RAM Replacement: 5 단계, 이미지 2/2
    • Carefully remove the battery from the case.
    • Flip the battery over.
    • Grip the battery cable tab and pull the cable from the battery to separate it from the device.
    • Do not bend or twist the battery during the removal.
  6. Dell Latitude 5401 RAM Replacement: 6 단계, 이미지 1/3 Dell Latitude 5401 RAM Replacement: 6 단계, 이미지 2/3 Dell Latitude 5401 RAM Replacement: 6 단계, 이미지 3/3
    • Gently pull the metal arms on both sides of the RAM stick away slightly to release it.
    • The RAM will pop up by a few millimeters.
    • Remove it at an angle and not straight up so you don't damage the socket.
    • Check online to see how to properly dispose of e-waste in your region.
  7. Dell Latitude 5401 RAM Replacement: 7 단계, 이미지 1/2 Dell Latitude 5401 RAM Replacement: 7 단계, 이미지 2/2
    • Insert the new RAM stick into the slot at the same angle that you used to remove the original.
    • Be sure to insert the grooved edge into the socket so the pins line up correctly to avoid damaging the socket and the RAM.
    • Push down on the RAM until you hear a "click".
    • The two metal arms should now hold the RAM in place.
  8. Dell Latitude 5401 RAM Replacement: 8 단계, 이미지 1/1
    • Reconnect the battery cable.
    • Screw the battery back into place.
  9. Dell Latitude 5401 RAM Replacement: 9 단계, 이미지 1/1
    • Using both hands, push the lower cover back onto the laptop.
    • You should hear a "click" when it is correctly attached.
    • Use a small Phillips screwdriver to secure the eight captive screws on the bottom cover.
결론
Congratulations, you have successfully replaced your laptop RAM, saved money, and reduced your carbon footprint!
다른 한 분이 해당 안내서를 완성하였습니다.
Jordan Millar
회원 가입일: 01/10/24
169 평판
안내서 1개 작성함
York University, Team 2-21, O'Regan Winter 2024 York University, Team 2-21, O'Regan Winter 2024 회원
YORK-O'REGAN-W24S2G21
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 15
전체 시간: 97
