소개
This guide will walk you through replacing the battery on a Latitude 5480, 5490, 5491 series laptop. You’ll need a #1 Phillips screwdriver, and about ten minutes of patience.
필요한 것
Use a Phillips screwdriver to remove the eight 5.6 mm screws that secure the lower case.
Grip the black battery cable connector loop and pull it directly up to disconnect the battery.
거의 끝나갑니다!
결론
