주요 콘텐츠로 건너뛰기
Dell Latitude 5480 Display Replacement
필요한 것
  1. Dell Latitude 5480 Display Replacement, Lower Case: 1 단계, 이미지 1/1
    • Use a Phillips screwdriver to remove the eight 5.6 mm screws that secure the lower case.
  2. Dell Latitude 5480 Display Replacement: 2 단계, 이미지 1/3 Dell Latitude 5480 Display Replacement: 2 단계, 이미지 2/3 Dell Latitude 5480 Display Replacement: 2 단계, 이미지 3/3
    • Insert an opening tool into the seam between the lower case and chassis.
    • Pry up around the perimeter of the device until the lower case fully releases.
    • Lift off the lower case.
  3. Dell Latitude 5480 Display Replacement, Battery: 3 단계, 이미지 1/2 Dell Latitude 5480 Display Replacement, Battery: 3 단계, 이미지 2/2
    • Remove the four 5.6 mm Phillips screws that secure the battery.
  4. Dell Latitude 5480 Display Replacement: 4 단계, 이미지 1/3 Dell Latitude 5480 Display Replacement: 4 단계, 이미지 2/3 Dell Latitude 5480 Display Replacement: 4 단계, 이미지 3/3
    • Lift the battery up and out of the chassis.
  5. Dell Latitude 5480 Display Replacement, Display: 5 단계, 이미지 1/3 Dell Latitude 5480 Display Replacement, Display: 5 단계, 이미지 2/3 Dell Latitude 5480 Display Replacement, Display: 5 단계, 이미지 3/3
    • Insert a plastic card between the bezel and the display.
    • Slide the plastic card beneath the entire bezel to sever the adhesive that secures the bezel.
    • Lift the bezel off of the display.
  6. Dell Latitude 5480 Display Replacement: 6 단계, 이미지 1/3 Dell Latitude 5480 Display Replacement: 6 단계, 이미지 2/3 Dell Latitude 5480 Display Replacement: 6 단계, 이미지 3/3
    • Remove the four 5.6 mm Phillips head screws, one at each corner, to release the display assembly.
    • Gently lift away the display panel and set it on top of the keyboard.
    • Take care not to strain the display assemble cable.
  7. Dell Latitude 5480 Display Replacement: 7 단계, 이미지 1/3 Dell Latitude 5480 Display Replacement: 7 단계, 이미지 2/3 Dell Latitude 5480 Display Replacement: 7 단계, 이미지 3/3
    • On the bottom of the back of the display panel, remove the tape that secures the cable connecting the screen to the base of the computer.
    • Flip up the display cable locking bar.
    • Disconnect the display connector.
    • Remove the display.
결론
Valencia Vidrine
회원 가입일: 02/16/24
457 평판
안내서 5개 작성하였습니다
University of Memphis, Team 2-2, Sneed Spring 2024 University of Memphis, Team 2-2, Sneed Spring 2024 회원
UM-SNEED-S24S2G2
4 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 6
30일 전: 29
전체 시간: 53
