주요 콘텐츠로 건너뛰기
Dell Latitude 5480 Power Jack Replacement
필요한 것
  1. Dell Latitude 5480 Power Jack Replacement, Lower Case: 1 단계, 이미지 1/1
    • Use a Phillips screwdriver to remove the eight 5.6 mm screws that secure the lower case.
  2. Dell Latitude 5480 Power Jack Replacement: 2 단계, 이미지 1/3 Dell Latitude 5480 Power Jack Replacement: 2 단계, 이미지 2/3 Dell Latitude 5480 Power Jack Replacement: 2 단계, 이미지 3/3
    • Insert an opening tool into the seam between the lower case and chassis.
    • Pry up around the perimeter of the device until the lower case fully releases.
    • Lift off the lower case.
  3. Dell Latitude 5480 Power Jack Replacement, Dell Latitude 5480 Battery Disconnection: 3 단계, 이미지 1/2 Dell Latitude 5480 Power Jack Replacement, Dell Latitude 5480 Battery Disconnection: 3 단계, 이미지 2/2
    • Grip the black battery cable connector loop and pull it directly up to disconnect the battery.
  4. Dell Latitude 5480 Power Jack Replacement, Power Jack: 4 단계, 이미지 1/3 Dell Latitude 5480 Power Jack Replacement, Power Jack: 4 단계, 이미지 2/3 Dell Latitude 5480 Power Jack Replacement, Power Jack: 4 단계, 이미지 3/3
    • Unscrew the right 3.7 mm screw that secures the fabric flap and the right side of the charging port bracket.
    • Carefully lift the flap out of the way of the left charging port bracket screw.
    • Unscrew the second 3.7 mm screw on the left side of the charging port bracket.
  5. Dell Latitude 5480 Power Jack Replacement: 5 단계, 이미지 1/3 Dell Latitude 5480 Power Jack Replacement: 5 단계, 이미지 2/3 Dell Latitude 5480 Power Jack Replacement: 5 단계, 이미지 3/3
    • Remove the metal bracket that secures the charging port.
    • Keep the fabric flap tucked out of the way.
    • Use the pointed edge of a spudger to push the charging port motherboard connector directly out of its port.
  6. Dell Latitude 5480 Power Jack Replacement: 6 단계, 이미지 1/1
    • Lift the entire charging port assembly up and out of the chassis.
결론
Valencia Vidrine
회원 가입일: 02/16/24
457 평판
안내서 5개 작성하였습니다
University of Memphis, Team 2-2, Sneed Spring 2024 University of Memphis, Team 2-2, Sneed Spring 2024 회원
UM-SNEED-S24S2G2
4 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 3
30일 전: 18
전체 시간: 58
