주요 콘텐츠로 건너뛰기
Dell Latitude 5480 Speakers Replacement
필요한 것
  1. Dell Latitude 5480 Speakers Replacement, Lower Case: 1 단계, 이미지 1/1
    • Use a Phillips screwdriver to remove the eight 5.6 mm screws that secure the lower case.
  2. Dell Latitude 5480 Speakers Replacement: 2 단계, 이미지 1/3 Dell Latitude 5480 Speakers Replacement: 2 단계, 이미지 2/3 Dell Latitude 5480 Speakers Replacement: 2 단계, 이미지 3/3
    • Insert an opening tool into the seam between the lower case and chassis.
    • Pry up around the perimeter of the device until the lower case fully releases.
    • Lift off the lower case.
  3. Dell Latitude 5480 Speakers Replacement, Battery: 3 단계, 이미지 1/2 Dell Latitude 5480 Speakers Replacement, Battery: 3 단계, 이미지 2/2
    • Remove the four 5.6 mm Phillips screws that secure the battery.
  4. Dell Latitude 5480 Speakers Replacement: 4 단계, 이미지 1/3 Dell Latitude 5480 Speakers Replacement: 4 단계, 이미지 2/3 Dell Latitude 5480 Speakers Replacement: 4 단계, 이미지 3/3
    • Lift the battery up and out of the chassis.
  5. Dell Latitude 5480 Speakers Replacement, Dell Latitude 5480 Battery Disconnection: 5 단계, 이미지 1/2 Dell Latitude 5480 Speakers Replacement, Dell Latitude 5480 Battery Disconnection: 5 단계, 이미지 2/2
    • Grip the black battery cable connector loop and pull it directly up to disconnect the battery.
  6. Dell Latitude 5480 Speakers Replacement, Speakers: 6 단계, 이미지 1/3 Dell Latitude 5480 Speakers Replacement, Speakers: 6 단계, 이미지 2/3 Dell Latitude 5480 Speakers Replacement, Speakers: 6 단계, 이미지 3/3
    • Flip the motherboard to view the speaker cable connection on the underside.
    • Flip up the speaker cable ZIF locking flap.
    • Disconnect the touchpad ribbon cable.
  7. Dell Latitude 5480 Speakers Replacement: 7 단계, 이미지 1/3 Dell Latitude 5480 Speakers Replacement: 7 단계, 이미지 2/3 Dell Latitude 5480 Speakers Replacement: 7 단계, 이미지 3/3
    • Disconnect the speaker cable by pulling it directly out of its motherboard port.
    • Do not pull on the wires.
  8. Dell Latitude 5480 Speakers Replacement: 8 단계, 이미지 1/3 Dell Latitude 5480 Speakers Replacement: 8 단계, 이미지 2/3 Dell Latitude 5480 Speakers Replacement: 8 단계, 이미지 3/3
    • Carefully unseat the wire between the two speakers from the clips.
    • Lift the speakers up and out of the chassis.
결론
Karston Salsbury
회원 가입일: 02/16/24
243 평판
안내서 2개 작성하였습니다
University of Memphis, Team 2-2, Sneed Spring 2024 University of Memphis, Team 2-2, Sneed Spring 2024 회원
UM-SNEED-S24S2G2
4 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 6
30일 전: 20
전체 시간: 57
