주요 콘텐츠로 건너뛰기
Dell Latitude 5521 Battery Replacement
필요한 것
  1. 주의: 1 단계는 진행 중으로 표시된 안내서에서 제공되었습니다.
    Dell Latitude 5521 Battery Replacement, Base Cover Removal: 1 단계, 이미지 1/3 Dell Latitude 5521 Battery Replacement, Base Cover Removal: 1 단계, 이미지 2/3 Dell Latitude 5521 Battery Replacement, Base Cover Removal: 1 단계, 이미지 3/3
    • Remove the 9 phillips #0 screws from the bottom of the case.
    • Carefully pry open the base cover with your spudger. Work your way around the case slowly, being careful not to damage any of the components inside.
    • Once removed you will have access to the contents of your case.
  2. Dell Latitude 5521 Battery Replacement, Battery removal: 2 단계, 이미지 1/3 Dell Latitude 5521 Battery Replacement, Battery removal: 2 단계, 이미지 2/3 Dell Latitude 5521 Battery Replacement, Battery removal: 2 단계, 이미지 3/3
    • Locate battery in case.
    • Locate three screws that will need to be removed.
    • Locate ribbon attached to battery cable a the top left of the battery and pull straight up on the ribbon.
    • Remove all three screws holding the battery on the main board.
결론
Michael Engle
회원 가입일: 10/14/21
461 평판
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 22
전체 시간: 1,075
