소개
If your laptop battery fails or no longer holds a sufficient charge you can easily replace it. This guide will advise you on how to replace the battery.
필요한 것
Remove the following ten T5 screws securing the lower case to the upper case.
Two will be 6mm, eight will be 3mm in length.
거의 끝나갑니다!
결론
다른 2명이 해당 안내서를 완성하였습니다.
