주요 콘텐츠로 건너뛰기
Dell Latitude 7390 Bottom Panel Replacement
필요한 것
  1. Dell Latitude 7390 Bottom Panel Replacement, Bottom Panel: 1 단계, 이미지 1/1
    • Orient your Dell Latitude 7390 laptop so that it is facing towards you as if you're going to open it.
  2. Dell Latitude 7390 Bottom Panel Replacement: 2 단계, 이미지 1/3 Dell Latitude 7390 Bottom Panel Replacement: 2 단계, 이미지 2/3 Dell Latitude 7390 Bottom Panel Replacement: 2 단계, 이미지 3/3
    • Flip your laptop over so that the bottom is facing up.
  3. Dell Latitude 7390 Bottom Panel Replacement: 3 단계, 이미지 1/1
    • Using your Phillips #1 screwdriver, remove the eight 6 mm screws around the border of the bottom panel.
  4. Dell Latitude 7390 Bottom Panel Replacement: 4 단계, 이미지 1/2 Dell Latitude 7390 Bottom Panel Replacement: 4 단계, 이미지 2/2
    • Using an opening tool or picks, work your way around the periphery and pry the back case off.
  5. Dell Latitude 7390 Bottom Panel Replacement: 5 단계, 이미지 1/1
    • Finally, lift the back panel off to uncover the inside of your Dell Latitude 7390.
결론
Julia Blahut
회원 가입일: 02/22/22
303 평판
안내서 2개 작성하였습니다
Clemson, Team 1-4, Hunter Spring 2022 Clemson, Team 1-4, Hunter Spring 2022 회원
CLEM-HUNTER-S22S1G4
5 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 8
30일 전: 22
전체 시간: 677
