소개
If you need to repair or replace the fan component in the Dell Latitude 7390, this guide shows you step-by-step how to access it.
Prior to starting this repair, be sure to turn off your laptop and unplug from the power adapter.
필요한 것
Orient your Dell Latitude 7390 laptop so that it is facing towards you as if you're going to open it.
Use the Phillips #1 screwdriver to remove the five 6 mm screws holding the battery in place along the edges of the battery.
다른 3명이 해당 안내서를 완성하였습니다.
