주요 콘텐츠로 건너뛰기
Dell Latitude 7390 SSD Replacement
필요한 것
  1. Dell Latitude 7390 SSD Replacement, Bottom Panel: 1 단계, 이미지 1/1
    • Orient your Dell Latitude 7390 laptop so that it is facing towards you as if you're going to open it.
  2. Dell Latitude 7390 SSD Replacement: 2 단계, 이미지 1/3 Dell Latitude 7390 SSD Replacement: 2 단계, 이미지 2/3 Dell Latitude 7390 SSD Replacement: 2 단계, 이미지 3/3
    • Flip your laptop over so that the bottom is facing up.
  3. Dell Latitude 7390 SSD Replacement: 3 단계, 이미지 1/1
    • Using your Phillips #1 screwdriver, remove the eight 6 mm screws around the border of the bottom panel.
  4. Dell Latitude 7390 SSD Replacement: 4 단계, 이미지 1/2 Dell Latitude 7390 SSD Replacement: 4 단계, 이미지 2/2
    • Using an opening tool or picks, work your way around the periphery and pry the back case off.
  5. Dell Latitude 7390 SSD Replacement: 5 단계, 이미지 1/1
    • Finally, lift the back panel off to uncover the inside of your Dell Latitude 7390.
  6. Dell Latitude 7390 SSD Replacement, Battery: 6 단계, 이미지 1/1
    • Make sure the laptop is turned OFF and unplugged from the power adapter before taking the battery out.
    • Use the Phillips #1 screwdriver to remove the five 6 mm screws holding the battery in place along the edges of the battery.
  7. Dell Latitude 7390 SSD Replacement: 7 단계, 이미지 1/3 Dell Latitude 7390 SSD Replacement: 7 단계, 이미지 2/3 Dell Latitude 7390 SSD Replacement: 7 단계, 이미지 3/3
    • Be careful not to break the connector by pulling too hard on the black tab.
    • Pull the black tab on the top of the connector to unplug the battery from the motherboard.
  8. Dell Latitude 7390 SSD Replacement: 8 단계, 이미지 1/1
    • Carefully lift the battery out of the laptop.
  9. Dell Latitude 7390 SSD Replacement, Solid State Drive (SSD): 9 단계, 이미지 1/1
    • Using a Phillips screwdriver, remove the 6 mm screw from the SSD cover.
  10. Dell Latitude 7390 SSD Replacement: 10 단계, 이미지 1/1
    • Remove the SSD card from under the silver plate.
결론
Thomas Pryor
회원 가입일: 02/22/22
86 평판
안내서 1개 작성함
Clemson, Team 1-4, Hunter Spring 2022 Clemson, Team 1-4, Hunter Spring 2022 회원
CLEM-HUNTER-S22S1G4
5 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 18
30일 전: 66
전체 시간: 2,967
