소개
Use this guide to replace a broken display assembly, or screen, on your Dell Latitude 7410 laptop.
필요한 것
Unplug all cables, fully shut down your laptop, and close the lid.
Use a Phillips screwdriver to loosen the eight captive screws securing the back cover.
Insert an opening pick between the right edge of the back cover and the frame, just below the middle right screw.
Slide your pick along the right edge to release the clips securing the back cover.
Insert your pick between the left edge of the back cover and the frame, next to the speaker cutout.
Slide your pick along the left edge to release the clips.
Insert your pick between the back cover and the right display-hinge to release the first clip along the back edge.
Slide your pick toward the left hinge until the second clip releases.
Insert your pick between the front edge of the back cover and the frame, just to the right of the bottom left screw.
Slide your pick toward the right edge until the front edge releases from the frame.
Grab the black pull tab on the head of the battery connector and pull straight up to disconnect it.
Use the flat end of a spudger to pry up the WWAN card cover from its clips on the I/O board.
Remove the cover.
Use your Phillips screwdriver to remove the 3 mm screw securing the WWAN cable bracket.
Remove the cable bracket.
Use your Phillips screwdriver to remove the 3 mm screw securing the antenna cable bracket.
Remove the antenna cable bracket.
Use your spudger to disconnect the antenna press connectors labeled 1 and 2 by prying the heads of their connectors straight up.
Lift the antenna cables out from their cable routing on the I/O board and move them away from the board.
Use your Phillips screwdriver to remove the two 2.7 mm screws securing the display cable bracket.
Use tweezers or your fingers to disconnect the leftmost wide connector by pulling it straight out of its socket.
Lay the laptop keyboard-side-down over the edge of a table with the display hanging below.
Use your Phillips screwdriver to remove the four 5.7 mm screws securing the hinges—two on each hinge.
Grab the display near the hinges and lift it straight up to free the hinges from the frame.
Remove the display assembly.
다른 한 분이 해당 안내서를 완성하였습니다.
