주요 콘텐츠로 건너뛰기
Dell Latitude 7410 Fan Replacement
필요한 것
  1. Dell Latitude 7410 Fan Replacement, Prepare your laptop for disassembly: 1 단계, 이미지 1/1
    • Allow your laptop's battery to drain below 25% before starting this repair—a charged battery may catch fire if damaged.
    • Unplug all cables, fully shut down your laptop, and close the lid.
  2. Dell Latitude 7410 Fan Replacement, Unfasten the back cover: 2 단계, 이미지 1/1
    • Use a Phillips screwdriver to loosen the eight captive screws securing the back cover.
  3. Dell Latitude 7410 Fan Replacement, Insert an opening pick: 3 단계, 이미지 1/2 Dell Latitude 7410 Fan Replacement, Insert an opening pick: 3 단계, 이미지 2/2
    • Insert an opening pick between the right edge of the back cover and the frame, just below the middle right screw.
  4. Dell Latitude 7410 Fan Replacement, Unclip the right edge: 4 단계, 이미지 1/2 Dell Latitude 7410 Fan Replacement, Unclip the right edge: 4 단계, 이미지 2/2
    • Slide your pick along the right edge to release the clips securing the back cover.
  5. Dell Latitude 7410 Fan Replacement, Unclip the left edge: 5 단계, 이미지 1/3 Dell Latitude 7410 Fan Replacement, Unclip the left edge: 5 단계, 이미지 2/3 Dell Latitude 7410 Fan Replacement, Unclip the left edge: 5 단계, 이미지 3/3
    • Insert your pick between the left edge of the back cover and the frame, next to the speaker cutout.
    • Slide your pick along the left edge to release the clips.
  6. Dell Latitude 7410 Fan Replacement, Unclip the back edge: 6 단계, 이미지 1/3 Dell Latitude 7410 Fan Replacement, Unclip the back edge: 6 단계, 이미지 2/3 Dell Latitude 7410 Fan Replacement, Unclip the back edge: 6 단계, 이미지 3/3
    • Insert your pick between the back cover and the right display-hinge to release the first clip along the back edge.
    • Slide your pick toward the left hinge until the second clip releases.
  7. Dell Latitude 7410 Fan Replacement, Unclip the front edge: 7 단계, 이미지 1/2 Dell Latitude 7410 Fan Replacement, Unclip the front edge: 7 단계, 이미지 2/2
    • Insert your pick between the front edge of the back cover and the frame, just to the right of the bottom left screw.
    • Slide your pick toward the right edge until the front edge releases from the frame.
  8. Dell Latitude 7410 Fan Replacement, Remove the back cover: 8 단계, 이미지 1/2 Dell Latitude 7410 Fan Replacement, Remove the back cover: 8 단계, 이미지 2/2
    • Remove the back cover.
  9. Dell Latitude 7410 Fan Replacement, Disconnect the battery: 9 단계, 이미지 1/2 Dell Latitude 7410 Fan Replacement, Disconnect the battery: 9 단계, 이미지 2/2
    • Grab the black pull tab on the head of the battery connector and pull straight up to disconnect it.
  10. Dell Latitude 7410 Fan Replacement, Disconnect the fan: 10 단계, 이미지 1/3 Dell Latitude 7410 Fan Replacement, Disconnect the fan: 10 단계, 이미지 2/3 Dell Latitude 7410 Fan Replacement, Disconnect the fan: 10 단계, 이미지 3/3
    • Use a spudger to press on alternating sides of the fan connector to "walk" it out of its socket.
  11. Dell Latitude 7410 Fan Replacement, Remove the WLAN cable bracket: 11 단계, 이미지 1/3 Dell Latitude 7410 Fan Replacement, Remove the WLAN cable bracket: 11 단계, 이미지 2/3 Dell Latitude 7410 Fan Replacement, Remove the WLAN cable bracket: 11 단계, 이미지 3/3
    • Use your Phillips screwdriver to remove the 3 mm screw securing the WLAN connector cover.
    • Remove the cover.
  12. Dell Latitude 7410 Fan Replacement, Unfasten the fan: 12 단계, 이미지 1/1
    • Use your Phillips screwdriver to remove the two 3 mm screws securing the fan.
  13. Dell Latitude 7410 Fan Replacement, Remove the fan: 13 단계, 이미지 1/3 Dell Latitude 7410 Fan Replacement, Remove the fan: 13 단계, 이미지 2/3 Dell Latitude 7410 Fan Replacement, Remove the fan: 13 단계, 이미지 3/3
    • Slide the fan out from the heatsink and remove it.
결론
Clay Eickemeyer
회원 가입일: 09/19/22
70,411 평판
안내서 453개 작성하였습니다
iFixit iFixit 회원
Staff
140 회원들
안내서 18,111개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 9
30일 전: 42
전체 시간: 262
