주요 콘텐츠로 건너뛰기
Dell Latitude 7420 Battery Replacement
필요한 것
  1. Dell Latitude 7420 Battery Replacement, Battery: 1 단계, 이미지 1/2 Dell Latitude 7420 Battery Replacement, Battery: 1 단계, 이미지 2/2
    • Remove the eight 7 mm screws from the from the back panel using the Phillips #1 screwdriver.
    • Please prevent the static damage by working from anti-static mat or wearing anti-static bracelet or touch the metal with hands to discharge.
  2. Dell Latitude 7420 Battery Replacement: 2 단계, 이미지 1/2 Dell Latitude 7420 Battery Replacement: 2 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Slide the opening pick in between the back cover and work your way around the edges to remove the back cover from the device.
    • Do not insert the pick tweezers too deep, since it may damage the other components on the motherboard.
  3. Dell Latitude 7420 Battery Replacement: 3 단계, 이미지 1/2 Dell Latitude 7420 Battery Replacement: 3 단계, 이미지 2/2
    • Using the Phillips #1 screwdriver, remove the five 5 mm screws.
  4. Dell Latitude 7420 Battery Replacement: 4 단계, 이미지 1/1
    • Disconnect the battery from the motherboard by gently pulling out the connector.
  5. Dell Latitude 7420 Battery Replacement: 5 단계, 이미지 1/2 Dell Latitude 7420 Battery Replacement: 5 단계, 이미지 2/2
    • Remove the battery from the laptop.
    • Before removing the battery from the laptop, please remove the cables that are attached on the battery.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Hong Lee
회원 가입일: 05/11/21
208 평판
안내서 1개 작성함
York University, Team S1-G15, Melo-Thaiss Summer 2021 York University, Team S1-G15, Melo-Thaiss Summer 2021 회원
YORK-MELO-THAISS-SU21S1G15
1 회원
안내서 2개 작성하였습니다
댓글 한 개
Do you know if you can upgrade the battery i.e. go from 42 to 63? I noticed the voltages were different.
Andrew Violet - 답글
댓글 쓰기
조회 통계:
24 시간 전: 12
7일 전: 80
30일 전: 373
전체 시간: 11,103
