주요 콘텐츠로 건너뛰기
Dell Latitude 7480 Battery Replacement
필요한 것
  1. Dell Latitude 7480  Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Make sure laptop is unplugged and powered off.
  2. Dell Latitude 7480  Battery Replacement, Remove the back cover: 2 단계, 이미지 1/2 Dell Latitude 7480  Battery Replacement, Remove the back cover: 2 단계, 이미지 2/2
    • Use a Phillips screwdriver to remove the eight screws securing the back cover.
    • Remove the back cover.
    I actually used the PH00 screw bit, but the PH0 screw bit fits as well.
    Jordan Rush - 답글
  3. Dell Latitude 7480  Battery Replacement, Unscrew the battery: 3 단계, 이미지 1/2 Dell Latitude 7480  Battery Replacement, Unscrew the battery: 3 단계, 이미지 2/2
    • Use a Phillips screwdriver to remove the two screws securing the battery in place.
    • Carefully peel the tape holding the battery cable in place.
    • Be careful not to puncture the battery.
  4. Dell Latitude 7480  Battery Replacement, Disconnect the battery cable: 4 단계, 이미지 1/3 Dell Latitude 7480  Battery Replacement, Disconnect the battery cable: 4 단계, 이미지 2/3 Dell Latitude 7480  Battery Replacement, Disconnect the battery cable: 4 단계, 이미지 3/3
    • Using the pull tabs pull up and remove the battery connector from the motherboard.
    • Remove the battery and set aside to remove the connector cable.
    • If your new battery did not come with a connector cable you will need this.
    • Remove the connector cable. Set aside to apply to the new battery.
  5. Dell Latitude 7480  Battery Replacement, Install the battery cable: 5 단계, 이미지 1/2 Dell Latitude 7480  Battery Replacement, Install the battery cable: 5 단계, 이미지 2/2
    • Connect the battery cable to the new battery. You can skip this step if your new battery came with one installed.
    • Connect one end of the battery cord to the battery. Route the cord in the channel between battery cells.
  6. Dell Latitude 7480  Battery Replacement, Install the new battery and test: 6 단계, 이미지 1/2 Dell Latitude 7480  Battery Replacement, Install the new battery and test: 6 단계, 이미지 2/2
    • Install the new battery by doing the steps in reverse. Be sure to test the device with and without AC power applied to the laptop.
    • Dispose of old battery properly and safely.
결론
다른 21명이 해당 안내서를 완성하였습니다.
brandon bradshaw
회원 가입일: 08/21/17
658 평판
안내서 1개 작성함
Kyber Computer Solutions LLC Kyber Computer Solutions LLC 회원
Business
1 회원
안내서 7개 작성하였습니다
댓글 2개
Thank you!
Didn’t need the entire teardown, just the batter Watt-hour and general shape to make sure I am buying the correct thing.
Keep up the great work for the community.
jeff5496 - 답글
It would also be helpful if you included the specification of the screws. For example, if you buy one without a battery.
omanoman - 답글
댓글 쓰기
조회 통계:
24 시간 전: 12
7일 전: 86
30일 전: 425
전체 시간: 41,156
