주요 콘텐츠로 건너뛰기
Dell Latitude 9410 2-in-1 Base Panel Replacement
필요한 것
  1. Dell Latitude 9410 2-in-1 Base Panel Replacement, Base Panel: 1 단계, 이미지 1/1
    • Ensure that the laptop is unplugged and powered off before beginning.
    • Place the laptop upside down on a flat surface.
  2. Dell Latitude 9410 2-in-1 Base Panel Replacement: 2 단계, 이미지 1/2 Dell Latitude 9410 2-in-1 Base Panel Replacement: 2 단계, 이미지 2/2
    • Use a Phillips #00 screwdriver to loosen the ten captive screws.
    • The screws are permanently fastened to the base panel; do not attempt to remove them.
  3. Dell Latitude 9410 2-in-1 Base Panel Replacement: 3 단계, 이미지 1/3 Dell Latitude 9410 2-in-1 Base Panel Replacement: 3 단계, 이미지 2/3 Dell Latitude 9410 2-in-1 Base Panel Replacement: 3 단계, 이미지 3/3
    • Carefully lift off the back panel.
결론
Stephanie Chavez Cardenas
회원 가입일: 02/08/22
100 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 9
전체 시간: 222
