주요 콘텐츠로 건너뛰기
Dell Latitude 9410 2-in-1 Battery Replacement
필요한 것
  1. Dell Latitude 9410 2-in-1 Battery Replacement, Base Panel: 1 단계, 이미지 1/1
    • Ensure that the laptop is unplugged and powered off before beginning.
    • Place the laptop upside down on a flat surface.
  2. Dell Latitude 9410 2-in-1 Battery Replacement: 2 단계, 이미지 1/2 Dell Latitude 9410 2-in-1 Battery Replacement: 2 단계, 이미지 2/2
    • Use a Phillips #00 screwdriver to loosen the ten captive screws.
    • The screws are permanently fastened to the base panel; do not attempt to remove them.
  3. Dell Latitude 9410 2-in-1 Battery Replacement: 3 단계, 이미지 1/3 Dell Latitude 9410 2-in-1 Battery Replacement: 3 단계, 이미지 2/3 Dell Latitude 9410 2-in-1 Battery Replacement: 3 단계, 이미지 3/3
    • Carefully lift off the back panel.
  4. Dell Latitude 9410 2-in-1 Battery Replacement, Battery: 4 단계, 이미지 1/2 Dell Latitude 9410 2-in-1 Battery Replacement, Battery: 4 단계, 이미지 2/2
    • Use a Philips #00 screwdriver to remove the five 3mm screws that secure the battery.
  5. Dell Latitude 9410 2-in-1 Battery Replacement: 5 단계, 이미지 1/3 Dell Latitude 9410 2-in-1 Battery Replacement: 5 단계, 이미지 2/3 Dell Latitude 9410 2-in-1 Battery Replacement: 5 단계, 이미지 3/3
    • Use a Philips #00 screwdriver to remove one 4.5 mm screw.
  6. Dell Latitude 9410 2-in-1 Battery Replacement: 6 단계, 이미지 1/2 Dell Latitude 9410 2-in-1 Battery Replacement: 6 단계, 이미지 2/2
    • Grip the battery cable near the plug and pull it straight out, in the direction of the cable.
  7. Dell Latitude 9410 2-in-1 Battery Replacement: 7 단계, 이미지 1/2 Dell Latitude 9410 2-in-1 Battery Replacement: 7 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Use tweezers to gently move the speaker ribbon cable away from the bottom of the battery.
    • The ribbon cable is thin and fragile; handle it carefully.
    • The ribbon cable only needs to be moved so that the battery can be removed; do not completely remove the ribbon cable.
  8. Dell Latitude 9410 2-in-1 Battery Replacement: 8 단계, 이미지 1/2 Dell Latitude 9410 2-in-1 Battery Replacement: 8 단계, 이미지 2/2
    • Lift the battery out with two hands.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Jessica Stephens
회원 가입일: 02/08/22
558 평판
안내서 5개 작성하였습니다
댓글 2개
This is a fantastic guide. Thanks for posting it.
EAR - 답글
Just one question about the speaker ribbon glued to the battery (Step 7). I can't remove the ribbon from my battery. The glue is very strong. I've pulled firmly, and I'm worried about breaking the cable. Any ideas about how to loosen the glue without damaging the computer, perhaps by applying heat or some sort of solvent?
EAR - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 7
30일 전: 28
전체 시간: 972
