주요 콘텐츠로 건너뛰기
Dell Latitude 9410 2-in-1 Display Replacement
필요한 것
  1. Dell Latitude 9410 2-in-1 Display Replacement, Base Panel: 1 단계, 이미지 1/1
    • Ensure that the laptop is unplugged and powered off before beginning.
    • Place the laptop upside down on a flat surface.
  2. Dell Latitude 9410 2-in-1 Display Replacement: 2 단계, 이미지 1/2 Dell Latitude 9410 2-in-1 Display Replacement: 2 단계, 이미지 2/2
    • Use a Phillips #00 screwdriver to loosen the ten captive screws.
    • The screws are permanently fastened to the base panel; do not attempt to remove them.
  3. Dell Latitude 9410 2-in-1 Display Replacement: 3 단계, 이미지 1/3 Dell Latitude 9410 2-in-1 Display Replacement: 3 단계, 이미지 2/3 Dell Latitude 9410 2-in-1 Display Replacement: 3 단계, 이미지 3/3
    • Carefully lift off the back panel.
  4. Dell Latitude 9410 2-in-1 Display Replacement, Battery: 4 단계, 이미지 1/2 Dell Latitude 9410 2-in-1 Display Replacement, Battery: 4 단계, 이미지 2/2
    • Use a Philips #00 screwdriver to remove the five 3mm screws that secure the battery.
  5. Dell Latitude 9410 2-in-1 Display Replacement: 5 단계, 이미지 1/3 Dell Latitude 9410 2-in-1 Display Replacement: 5 단계, 이미지 2/3 Dell Latitude 9410 2-in-1 Display Replacement: 5 단계, 이미지 3/3
    • Use a Philips #00 screwdriver to remove one 4.5 mm screw.
  6. Dell Latitude 9410 2-in-1 Display Replacement: 6 단계, 이미지 1/2 Dell Latitude 9410 2-in-1 Display Replacement: 6 단계, 이미지 2/2
    • Grip the battery cable near the plug and pull it straight out, in the direction of the cable.
  7. Dell Latitude 9410 2-in-1 Display Replacement: 7 단계, 이미지 1/2 Dell Latitude 9410 2-in-1 Display Replacement: 7 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Use tweezers to gently move the speaker ribbon cable away from the bottom of the battery.
    • The ribbon cable is thin and fragile; handle it carefully.
    • The ribbon cable only needs to be moved so that the battery can be removed; do not completely remove the ribbon cable.
  8. Dell Latitude 9410 2-in-1 Display Replacement: 8 단계, 이미지 1/2 Dell Latitude 9410 2-in-1 Display Replacement: 8 단계, 이미지 2/2
    • Lift the battery out with two hands.
  9. Dell Latitude 9410 2-in-1 Display Replacement, Display: 9 단계, 이미지 1/3 Dell Latitude 9410 2-in-1 Display Replacement, Display: 9 단계, 이미지 2/3 Dell Latitude 9410 2-in-1 Display Replacement, Display: 9 단계, 이미지 3/3
    • Carefully detach the ribbon that is affixed to the HDD.
    • Using a Philips #00 screwdriver, unscrew the 3, top left and top right 4mm screws located about the hinge.
  10. Dell Latitude 9410 2-in-1 Display Replacement: 10 단계, 이미지 1/2 Dell Latitude 9410 2-in-1 Display Replacement: 10 단계, 이미지 2/2
    • Carefully detach the back panel from the screen via the hinges.
결론
Brenden William Johnson
회원 가입일: 10/04/22
334 평판
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 10
전체 시간: 402
