주요 콘텐츠로 건너뛰기
Dell Latitude 9410 2-in-1 Fan Replacement
필요한 것
  1. Dell Latitude 9410 2-in-1 Fan Replacement, Base Panel: 1 단계, 이미지 1/1
    • Ensure that the laptop is unplugged and powered off before beginning.
    • Place the laptop upside down on a flat surface.
  2. Dell Latitude 9410 2-in-1 Fan Replacement: 2 단계, 이미지 1/2 Dell Latitude 9410 2-in-1 Fan Replacement: 2 단계, 이미지 2/2
    • Use a Phillips #00 screwdriver to loosen the ten captive screws.
    • The screws are permanently fastened to the base panel; do not attempt to remove them.
  3. Dell Latitude 9410 2-in-1 Fan Replacement: 3 단계, 이미지 1/3 Dell Latitude 9410 2-in-1 Fan Replacement: 3 단계, 이미지 2/3 Dell Latitude 9410 2-in-1 Fan Replacement: 3 단계, 이미지 3/3
    • Carefully lift off the back panel.
  4. Dell Latitude 9410 2-in-1 Fan Replacement, Fan: 4 단계, 이미지 1/3 Dell Latitude 9410 2-in-1 Fan Replacement, Fan: 4 단계, 이미지 2/3 Dell Latitude 9410 2-in-1 Fan Replacement, Fan: 4 단계, 이미지 3/3
    • Carefully peel back and remove the black tape around the top left corner of the motherboard.
  5. Dell Latitude 9410 2-in-1 Fan Replacement: 5 단계, 이미지 1/2 Dell Latitude 9410 2-in-1 Fan Replacement: 5 단계, 이미지 2/2
    • Use a Philips #00 screwdriver to remove the two 2 mm screws.
    • After the screws are removed, lift off the silver bracket, toward the top left of the fan.
  6. Dell Latitude 9410 2-in-1 Fan Replacement: 6 단계, 이미지 1/2 Dell Latitude 9410 2-in-1 Fan Replacement: 6 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Grip both sides of the fan connector plug with tweezers, and pull directly backwards, toward the cables, until the plug disconnects.
  7. Dell Latitude 9410 2-in-1 Fan Replacement: 7 단계, 이미지 1/2 Dell Latitude 9410 2-in-1 Fan Replacement: 7 단계, 이미지 2/2
    • Lift the fan up and out.
결론
Jessica Stephens
회원 가입일: 02/08/22
558 평판
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 8
30일 전: 30
전체 시간: 464
