주요 콘텐츠로 건너뛰기
Dell Latitude 9410 2-in-1 Wi-Fi Card Replacement
필요한 것
  1. Dell Latitude 9410 2-in-1 Wi-Fi Card Replacement, Base Panel: 1 단계, 이미지 1/1
    • Ensure that the laptop is unplugged and powered off before beginning.
    • Place the laptop upside down on a flat surface.
  2. Dell Latitude 9410 2-in-1 Wi-Fi Card Replacement: 2 단계, 이미지 1/2 Dell Latitude 9410 2-in-1 Wi-Fi Card Replacement: 2 단계, 이미지 2/2
    • Use a Phillips #00 screwdriver to loosen the ten captive screws.
    • The screws are permanently fastened to the base panel; do not attempt to remove them.
  3. Dell Latitude 9410 2-in-1 Wi-Fi Card Replacement: 3 단계, 이미지 1/3 Dell Latitude 9410 2-in-1 Wi-Fi Card Replacement: 3 단계, 이미지 2/3 Dell Latitude 9410 2-in-1 Wi-Fi Card Replacement: 3 단계, 이미지 3/3
    • Carefully lift off the back panel.
  4. Dell Latitude 9410 2-in-1 Wi-Fi Card Replacement, Wi-Fi Card: 4 단계, 이미지 1/2 Dell Latitude 9410 2-in-1 Wi-Fi Card Replacement, Wi-Fi Card: 4 단계, 이미지 2/2
    • Remove the protective film located at the top left corner of the motherboard.
  5. Dell Latitude 9410 2-in-1 Wi-Fi Card Replacement: 5 단계, 이미지 1/2 Dell Latitude 9410 2-in-1 Wi-Fi Card Replacement: 5 단계, 이미지 2/2
    • Use a Philips #00 screwdriver to remove the 2mm screw located above the wifi card.
  6. Dell Latitude 9410 2-in-1 Wi-Fi Card Replacement: 6 단계, 이미지 1/1
    • Remove the black and white wires located above the wifi card using a blue, plastic spudger.
  7. Dell Latitude 9410 2-in-1 Wi-Fi Card Replacement: 7 단계, 이미지 1/1
    • Remove the Wifi card from its slot in the motherboard.
결론
Brenden William Johnson
회원 가입일: 10/04/22
334 평판
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 14
전체 시간: 359
