소개
This is an in depth instruction manual to replace the baseplate for your Dell Latitude 9510 laptop. The baseplate, also known as a backplate, is used to protect the inner electronics of the computer from small drops and spills. This is a common replacement due to dropping the device or improperly removing the backplate making it break.
필요한 것
Flip the device so that the base plate is facing you.
Use a Phillips #0 screwdriver to remove the nine 5.5 mm screws securing the base plate.
거의 끝나갑니다!
결론
