소개
Not much prior knowledge is required before starting. According to Dell, however, you must have the following tools:
"‡#0 and #1 magnetized Phillips-head screwdrivers
‡ Small flat-blade screwdriver
‡ 5-mm socket wrench
‡ 7-mm socket wrench
‡ Small plastic scribe"
(Guide found at: http://tim.id.au/laptops/dell/latitude%2...)
  1. Flip laptop over. Flip laptop over.
    • Flip laptop over.
  2. Remove the screws over the RAM door Remove the screws over the RAM door
    • Remove the screws over the RAM door
  3. US$100 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
    상점 둘러보기
  4. Open the RAM door. Open the RAM door.
    • Open the RAM door.
  5. Carefully pull the tabs over the RAM chip down - the RAM will spring up. Carefully pull the tabs over the RAM chip down - the RAM will spring up.
    • Carefully pull the tabs over the RAM chip down - the RAM will spring up.
  6. Remove the RAM from the socket and insert replacement RAM.
    • Remove the RAM from the socket and insert replacement RAM.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Axuak
회원 가입일: 2011년 05월 04일
331 평판
안내서 2개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 2
전체 시간: 2,073
