주요 콘텐츠로 건너뛰기
Dell Latitude D430 Keyboard Replacement
필요한 것
  1. Dell Latitude D430 Keyboard Replacement, Keyboard: 1 단계, 이미지 1/1
    • Lay the laptop flat with the screen facing upward. This will allow you to have the most room while performing the keyboard replacement.
  2. Dell Latitude D430 Keyboard Replacement: 2 단계, 이미지 1/2 Dell Latitude D430 Keyboard Replacement: 2 단계, 이미지 2/2
    • Identify the plastic cover located directly below the screen.
    • Carefully remove the plastic cover by lifting both ends of the cover.
    • This piece is very fragile, so be sure not to break this piece. It requires minimal force to remove this piece.
  3. Dell Latitude D430 Keyboard Replacement: 3 단계, 이미지 1/3 Dell Latitude D430 Keyboard Replacement: 3 단계, 이미지 2/3 Dell Latitude D430 Keyboard Replacement: 3 단계, 이미지 3/3
    • There are 3 screws that should be exposed now.
    • Use a Phillips 00 screwdriver to remove all 3 of the screws shown in the pictures.
  4. Dell Latitude D430 Keyboard Replacement: 4 단계, 이미지 1/3 Dell Latitude D430 Keyboard Replacement: 4 단계, 이미지 2/3 Dell Latitude D430 Keyboard Replacement: 4 단계, 이미지 3/3
    • Gently lift the keyboard from the top.
    • At the bottom of the keyboard, there will be ribbons connecting it to the motherboard. Be sure not to tear the ribbons.
    • Lift the clamps that are holding the ribbons in place in order to remove them. You should be able to remove the keyboard at this point.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Jacob Pham
회원 가입일: 09/21/18
109 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 9
전체 시간: 397
