주요 콘텐츠로 건너뛰기
Dell Latitude D430 Wireless Adapter Replacement
필요한 것
  1. Dell Latitude D430 Wireless Adapter Replacement, Wireless Adapter: 1 단계, 이미지 1/3 Dell Latitude D430 Wireless Adapter Replacement, Wireless Adapter: 1 단계, 이미지 2/3 Dell Latitude D430 Wireless Adapter Replacement, Wireless Adapter: 1 단계, 이미지 3/3
    • Flip the laptop so you are able to see the bottom.
  2. Dell Latitude D430 Wireless Adapter Replacement: 2 단계, 이미지 1/2 Dell Latitude D430 Wireless Adapter Replacement: 2 단계, 이미지 2/2
    • Use a Phillips #00 screwdriver to remove the three screws that secure the small "L" shaped backplate.
  3. Dell Latitude D430 Wireless Adapter Replacement: 3 단계, 이미지 1/1
    • Once all 3 screws have been removed, carefully remove the panel by grabbing the edges, and pulling up.
  4. Dell Latitude D430 Wireless Adapter Replacement: 4 단계, 이미지 1/3 Dell Latitude D430 Wireless Adapter Replacement: 4 단계, 이미지 2/3 Dell Latitude D430 Wireless Adapter Replacement: 4 단계, 이미지 3/3
    • Identify the two pins connecting the wireless adapter to the motherboard. (The wireless adapter will say WLAN on it.)
    • Carefully pull up on each pin and remove them from the wireless adapter.
    • Note that there are no wires/cables connecting the wireless adapter to the motherboard.
  5. Dell Latitude D430 Wireless Adapter Replacement: 5 단계, 이미지 1/2 Dell Latitude D430 Wireless Adapter Replacement: 5 단계, 이미지 2/2
    • Pull back on the two metal tabs holding the wireless adapter down.
    • After the two metal tabs are pulled, the card will pop up.
  6. Dell Latitude D430 Wireless Adapter Replacement: 6 단계, 이미지 1/1
    • Pull the wireless adapter out away from where it was connected.
결론
Parker Wiley
회원 가입일: 06/21/18
382 평판
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 14
전체 시간: 511
