주요 콘텐츠로 건너뛰기
Dell Latitude D530 CD ROM Replacement
필요한 것
  1. Dell Latitude D530 CD ROM Replacement, CD ROM Drive: 1 단계, 이미지 1/3 Dell Latitude D530 CD ROM Replacement, CD ROM Drive: 1 단계, 이미지 2/3 Dell Latitude D530 CD ROM Replacement, CD ROM Drive: 1 단계, 이미지 3/3
    • The CD ROM Drive is located on the right side of the laptop.
    • Use the Phillips #1 to unscrew the 6mm lock screw. The screw is located underneath the CD-ROM Drive with a lock symbol on it.
  2. Dell Latitude D530 CD ROM Replacement: 2 단계, 이미지 1/3 Dell Latitude D530 CD ROM Replacement: 2 단계, 이미지 2/3 Dell Latitude D530 CD ROM Replacement: 2 단계, 이미지 3/3
    • remove the CD ROM Drive: push the indicated button in towards the laptop and release. The button will pop out.
  3. Dell Latitude D530 CD ROM Replacement: 3 단계, 이미지 1/2 Dell Latitude D530 CD ROM Replacement: 3 단계, 이미지 2/2
    • Remove the CD ROM Drive: Pull on the now released button and the CD ROM Drive will come out.
결론
Kyle Cabral
회원 가입일: 03/19/18
604 평판
안내서 4개 작성하였습니다
UMass Dartmouth, Team S2-G6, Bernier Spring 2018 UMass Dartmouth, Team S2-G6, Bernier Spring 2018 회원
UMASSD-BERNIER-S18S2G6
3 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 14
전체 시간: 491
