소개
You can tell if your hard drive is broken if you get a 'hard drive missing/not detected' error upon computer startup. If this is the case, you need to buy a hard drive and replace the old one with it. Most hard drives can withstand being handled, but it is good to be careful with it nonetheless.
필요한 것
The hard drive will be located in the side of the laptop.
Unscrew the two bottom 6mm screws using Phillips #1.
다른 한 분이 해당 안내서를 완성하였습니다.
