주요 콘텐츠로 건너뛰기
Dell Latitude D600 Display Replacement
필요한 것
  1. Dell Latitude D600 Display Replacement, Display: 1 단계, 이미지 1/1
    • Remove the 6 screws underneath the rubber things - located in red
  2. Dell Latitude D600 Display Replacement: 2 단계, 이미지 1/2 Dell Latitude D600 Display Replacement: 2 단계, 이미지 2/2
    • Use your spudger to pry off the front case
    • Go all around the perimeter and pop it off
  3. Dell Latitude D600 Display Replacement: 3 단계, 이미지 1/1
    • Remove the 6 screws holding in the display screen
  4. Dell Latitude D600 Display Replacement: 4 단계, 이미지 1/3 Dell Latitude D600 Display Replacement: 4 단계, 이미지 2/3 Dell Latitude D600 Display Replacement: 4 단계, 이미지 3/3
    • Remove the screw holding in the display cable connector
    • Pull the black tab up to remove the display cable connector
  5. Dell Latitude D600 Display Replacement: 5 단계, 이미지 1/1
    • Slowly Remove the wire from the joints holding it in
  6. Dell Latitude D600 Display Replacement: 6 단계, 이미지 1/2 Dell Latitude D600 Display Replacement: 6 단계, 이미지 2/2
    • The computer is happy you are fixing him
    • Thats it, display is now removed feel free to replace it by doing the steps in reverse
결론
다른 3명이 해당 안내서를 완성하였습니다.
Joseph
회원 가입일: 07/16/14
1,497 평판
안내서 5개 작성하였습니다
댓글 한 개
I see you removed the keyboard by seeing it in the background of the last image however, I do not see the steps instructing everyone on how to remove the keyboard.
Darren - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 10
전체 시간: 2,083
