주요 콘텐츠로 건너뛰기
Dell Latitude D600 RAM (Main Memory) Replacement
필요한 것
  1. Dell Latitude D600 RAM (Main Memory) Replacement, Battery: 1 단계, 이미지 1/1
    • Find the battery
  2. Dell Latitude D600 RAM (Main Memory) Replacement: 2 단계, 이미지 1/2 Dell Latitude D600 RAM (Main Memory) Replacement: 2 단계, 이미지 2/2
    • Pull the tab to release the battery
  3. Dell Latitude D600 RAM (Main Memory) Replacement: 3 단계, 이미지 1/1
    • Pull the battery out
  4. Dell Latitude D600 RAM (Main Memory) Replacement, RAM (Main Memory): 4 단계, 이미지 1/2 Dell Latitude D600 RAM (Main Memory) Replacement, RAM (Main Memory): 4 단계, 이미지 2/2
    • Find the panel underneath the microsoft product key sticker, the panel is labeled with an M
    • Unscrew the single screw above the M
  5. Dell Latitude D600 RAM (Main Memory) Replacement: 5 단계, 이미지 1/3 Dell Latitude D600 RAM (Main Memory) Replacement: 5 단계, 이미지 2/3 Dell Latitude D600 RAM (Main Memory) Replacement: 5 단계, 이미지 3/3
    • Pull off the panel to reveal the RAM
    • RAM is held in by two tabs, pull each tab to the side and the RAM will pop up
  6. Dell Latitude D600 RAM (Main Memory) Replacement: 6 단계, 이미지 1/1
    • Once the RAM is popped up, slowly pull it out of the slot
  7. Dell Latitude D600 RAM (Main Memory) Replacement: 7 단계, 이미지 1/3 Dell Latitude D600 RAM (Main Memory) Replacement: 7 단계, 이미지 2/3 Dell Latitude D600 RAM (Main Memory) Replacement: 7 단계, 이미지 3/3
    • To add or replace RAM, place the memory into the slot at an angle
    • Make sure you line it up correctly
    • If it is in correctly it should stay up at an angle by itself
    • Then push down in the middle until it clicks into place
  8. Dell Latitude D600 RAM (Main Memory) Replacement: 8 단계, 이미지 1/1
    • The RAM should be secured by the tabs where the two semi circles are on the RAM
    • If it is not secure, just gently pull it out and try again, use the images to help you out
결론
다른 6명이 해당 안내서를 완성하였습니다.
Joseph
회원 가입일: 07/16/14
1,497 평판
안내서 5개 작성하였습니다
댓글 한 개
Almost perfect: easy; clear;
Herman - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 9
전체 시간: 2,828
