주요 콘텐츠로 건너뛰기
Dell Latitude D600 Wireless WiFi Card Replacement
필요한 것
  1. Dell Latitude D600 Wireless WiFi Card Replacement, Battery: 1 단계, 이미지 1/1
    • Find the battery
  2. Dell Latitude D600 Wireless WiFi Card Replacement: 2 단계, 이미지 1/2 Dell Latitude D600 Wireless WiFi Card Replacement: 2 단계, 이미지 2/2
    • Pull the tab to release the battery
  3. Dell Latitude D600 Wireless WiFi Card Replacement: 3 단계, 이미지 1/1
    • Pull the battery out
  4. Dell Latitude D600 Wireless WiFi Card Replacement, Wireless WiFi Card: 4 단계, 이미지 1/1
    • Use your screwdriver to unscrew and lift up the panel on the right labeled with a C
  5. Dell Latitude D600 Wireless WiFi Card Replacement: 5 단계, 이미지 1/1
    • Pull off the two wires connected to the wireless card
    • They should come off fairly easy
  6. Dell Latitude D600 Wireless WiFi Card Replacement: 6 단계, 이미지 1/2 Dell Latitude D600 Wireless WiFi Card Replacement: 6 단계, 이미지 2/2
    • Pull the two tabs away from the card and pull up on the intel card
    • Then pull it away from the holding slot to remove it
  7. Dell Latitude D600 Wireless WiFi Card Replacement: 7 단계, 이미지 1/2 Dell Latitude D600 Wireless WiFi Card Replacement: 7 단계, 이미지 2/2
    • When placing in your new wireless card, connect the two wires before inserting into the slot
    • Then line it up, put the card in at an angle and push down so the side tabs lock it into place
결론
다른 6명이 해당 안내서를 완성하였습니다.
Joseph
회원 가입일: 07/16/14
1,497 평판
안내서 5개 작성하였습니다
댓글 한 개
Hi,
dell latitude D600 Laptop
Can you please help me, I cant release my wireless card, by pulling the tabs on cards sides.?
It just doesn't release the card to pull out, is there any other way I can remove my card.?
Email me if you can .
robert.wilson407@ntlworld.com
Thanking you Rob
rob wilson - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 6
전체 시간: 2,618
