주요 콘텐츠로 건너뛰기
Dell Latitude D610 RAM Replacement
필요한 것
  1. Dell Latitude D610 RAM Replacement, Battery: 1 단계, 이미지 1/2 Dell Latitude D610 RAM Replacement, Battery: 1 단계, 이미지 2/2
    • Remove the 3.9 mm Phillips #1 screw from the battery compartment.
  2. Dell Latitude D610 RAM Replacement: 2 단계, 이미지 1/3 Dell Latitude D610 RAM Replacement: 2 단계, 이미지 2/3 Dell Latitude D610 RAM Replacement: 2 단계, 이미지 3/3
    • Locate the laptop battery release button lock
    • Push the battery release in the direction of the arrow, and pull upward.
  3. Dell Latitude D610 RAM Replacement: 3 단계, 이미지 1/1
    • Remove the battery from its compartment.
  4. Dell Latitude D610 RAM Replacement, RAM: 4 단계, 이미지 1/3 Dell Latitude D610 RAM Replacement, RAM: 4 단계, 이미지 2/3 Dell Latitude D610 RAM Replacement, RAM: 4 단계, 이미지 3/3
    • Remove the 3.9mm Philips #1 screw holding the panel for the RAM.
  5. Dell Latitude D610 RAM Replacement: 5 단계, 이미지 1/2 Dell Latitude D610 RAM Replacement: 5 단계, 이미지 2/2
    • Lift and remove the panel.
  6. Dell Latitude D610 RAM Replacement: 6 단계, 이미지 1/3 Dell Latitude D610 RAM Replacement: 6 단계, 이미지 2/3 Dell Latitude D610 RAM Replacement: 6 단계, 이미지 3/3
    • Using two fingers, push the silver ends away from the RAM until the RAM is released.
  7. Dell Latitude D610 RAM Replacement: 7 단계, 이미지 1/3 Dell Latitude D610 RAM Replacement: 7 단계, 이미지 2/3 Dell Latitude D610 RAM Replacement: 7 단계, 이미지 3/3
    • Lift the RAM from its slot.
    • Remove the RAM completely.
결론
다른 6명이 해당 안내서를 완성하였습니다.
Jordan Barham
회원 가입일: 01/26/14
459 평판
안내서 3개 작성하였습니다
Cal Poly, Team 6-24, Maness Winter 2014 Cal Poly, Team 6-24, Maness Winter 2014 회원
CPSU-MANESS-W14S6G24
4 회원들
안내서 5개 작성하였습니다
댓글 한 개
This model has two RAM slots. The second one is under the keypad. Carefully remove the bezel at the top of the keypad, remove the two screws holding the keypad down, then remove the keypad to expose the second slot. This RAM slot is a little bit more difficult to get to than the one on the back of the laptop, but is still very easy to access and change out.
Chris Kelley - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 6
전체 시간: 1,642
