이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Locate the laptop battery release button lock
Push the battery release in the direction of the arrow, and pull upward.
Using two fingers, push the silver ends away from the RAM until the RAM is released.
다른 6명이 해당 안내서를 완성하였습니다.
댓글 한 개
This model has two RAM slots. The second one is under the keypad. Carefully remove the bezel at the top of the keypad, remove the two screws holding the keypad down, then remove the keypad to expose the second slot. This RAM slot is a little bit more difficult to get to than the one on the back of the laptop, but is still very easy to access and change out.
