주요 콘텐츠로 건너뛰기
Dell Latitude D620 Display Replacement
필요한 것
  1. Dell Latitude D620 Display Replacement, Keyboard: 1 단계, 이미지 1/1
    • Power down the laptop and remove the battery.
    • Open the laptop cover all of the way.
    Mera display ka masla hai
    manaqib arif - 답글
  2. Dell Latitude D620 Display Replacement: 2 단계, 이미지 1/3 Dell Latitude D620 Display Replacement: 2 단계, 이미지 2/3 Dell Latitude D620 Display Replacement: 2 단계, 이미지 3/3
    • Locate the notch under the cover at the top of the keyboard
    • Using the spudger as a lever, lift the plastic covering
    • Carefully remove the rest of the covering from right to left
  3. Dell Latitude D620 Display Replacement: 3 단계, 이미지 1/1
    • Unscrew the top portion of the keyboard using a #00 screwdriver
  4. Dell Latitude D620 Display Replacement: 4 단계, 이미지 1/1
    • Hold keyboard from the top and gently pull towards the LCD screen to remove the keyboard from the case
    • Don't pull on the keyboard too forcefully because it is attached to the motherboard with a short, thin ribbon cable
  5. Dell Latitude D620 Display Replacement: 5 단계, 이미지 1/2 Dell Latitude D620 Display Replacement: 5 단계, 이미지 2/2
    • Once keyboard is out of the case, lay it face-down on the track pad
  6. Dell Latitude D620 Display Replacement: 6 단계, 이미지 1/2 Dell Latitude D620 Display Replacement: 6 단계, 이미지 2/2
    • Using a small spudger, pull back on the black bar to release the blue lever
  7. Dell Latitude D620 Display Replacement: 7 단계, 이미지 1/1
    • Pull up on the metal bar connected to the socket to detach the ribbon cable
  8. Dell Latitude D620 Display Replacement, Display: 8 단계, 이미지 1/1
    • Detach cables that connect the display to the body of the laptop
  9. Dell Latitude D620 Display Replacement: 9 단계, 이미지 1/1
    • Disconnect the black cable attached to the motherboard
  10. Dell Latitude D620 Display Replacement: 10 단계, 이미지 1/2 Dell Latitude D620 Display Replacement: 10 단계, 이미지 2/2
    • Close the laptop lid
    • Turn the laptop over onto its backside
    • Unscrew the two screws shown in the picture using a #00 screwdriver
  11. Dell Latitude D620 Display Replacement: 11 단계, 이미지 1/2 Dell Latitude D620 Display Replacement: 11 단계, 이미지 2/2
    • Face the laptop's back ports towards you
    • Unscrew the two screws labeled in the picture using a #00 screwdriver
  12. Dell Latitude D620 Display Replacement: 12 단계, 이미지 1/1
    • Turn the laptop over again so it's right-side up
    • Open the display, and pull the display up and out of the laptop's body
  13. Dell Latitude D620 Display Replacement: 13 단계, 이미지 1/1
    • Remove the circular rubber pads as outlined in the picture using a spudger
  14. Dell Latitude D620 Display Replacement: 14 단계, 이미지 1/1
    • Unscrew the screws that were under the rubber circles using the #00 screwdriver
  15. Dell Latitude D620 Display Replacement: 15 단계, 이미지 1/1
    • Carefully use a spudger to work around the edge of the screen to lift off the plastic cover
    • Be very careful while doing this as the plastic snaps easily
  16. Dell Latitude D620 Display Replacement: 16 단계, 이미지 1/1
    • Remove the screws outlined in the picture
  17. Dell Latitude D620 Display Replacement: 17 단계, 이미지 1/1
    • Carefully lift the LCD screen out of its casing
결론
다른 19명이 해당 안내서를 완성하였습니다.
Miguel Wong
회원 가입일: 04/15/10
562 평판
안내서 3개 작성하였습니다
Cal Poly, Team 24-35, Regan Spring 2010 Cal Poly, Team 24-35, Regan Spring 2010 회원
CPSU-REGAN-S10S24G35
4 회원들
안내서 4개 작성하였습니다
댓글 한 개
Check out this replacement screen at a great price on bcdelectrostore.com
http://www.bcdelectrostore.com/magento/l...
bob harris - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 8
30일 전: 36
전체 시간: 33,014
