주요 콘텐츠로 건너뛰기
Dell Latitude D620 Hard Drive Replacement
필요한 것
    • First, as always, power down the laptop and remove the battery., This can be done by pulling the two tabs above the battery and then simply pulling out the battery.
  1. Dell Latitude D620 Hard Drive Replacement, Unscrew the drive bay: 2 단계, 이미지 1/1
    • Now, remove the two drive screws, located in the bottom right of the laptop. These are helpfully labeled with a cylindrical hard drive icon.
  2. Dell Latitude D620 Hard Drive Replacement, Removing the drive bay: 3 단계, 이미지 1/1
    • Now, simply pull the hard drive out
  3. Dell Latitude D620 Hard Drive Replacement, Removing the drive from its cage: 4 단계, 이미지 1/1
    • Now, remove the drive from its cage by removing the single screw holding it in. See the picture for help
결론
To reassemble your device, attach your drive to the bay and follow these instructions in reverse order.
다른 5명이 해당 안내서를 완성하였습니다.
James Martin
회원 가입일: 03/19/16
231 평판
안내서 1개 작성함
2 댓글
can i install 1 tr wd sshd 2.5 inch on dell d620?
does it support it??
please answer my quastion.
pouranvary@gmail.com
mohammad - 답글
can my dell d620 support 1 tr sshd?
does it support 1 tr hard?
please answer my quastion:
mohammad - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 11
30일 전: 40
전체 시간: 2,108
