주요 콘텐츠로 건너뛰기
Dell Latitude D620 Keyboard Replacement
필요한 것
  1. Dell Latitude D620 Keyboard Replacement, Keyboard: 1 단계, 이미지 1/1
    • Power down the laptop and remove the battery.
    • Open the laptop cover all of the way.
  2. Dell Latitude D620 Keyboard Replacement: 2 단계, 이미지 1/3 Dell Latitude D620 Keyboard Replacement: 2 단계, 이미지 2/3 Dell Latitude D620 Keyboard Replacement: 2 단계, 이미지 3/3
    • Locate the notch under the cover at the top of the keyboard
    • Using the spudger as a lever, lift the plastic covering
    • Carefully remove the rest of the covering from right to left
  3. Dell Latitude D620 Keyboard Replacement: 3 단계, 이미지 1/1
    • Unscrew the top portion of the keyboard using a #00 screwdriver
  4. Dell Latitude D620 Keyboard Replacement: 4 단계, 이미지 1/1
    • Hold keyboard from the top and gently pull towards the LCD screen to remove the keyboard from the case
    • Don't pull on the keyboard too forcefully because it is attached to the motherboard with a short, thin ribbon cable
  5. Dell Latitude D620 Keyboard Replacement: 5 단계, 이미지 1/2 Dell Latitude D620 Keyboard Replacement: 5 단계, 이미지 2/2
    • Once keyboard is out of the case, lay it face-down on the track pad
  6. Dell Latitude D620 Keyboard Replacement: 6 단계, 이미지 1/2 Dell Latitude D620 Keyboard Replacement: 6 단계, 이미지 2/2
    • Using a small spudger, pull back on the black bar to release the blue lever
  7. Dell Latitude D620 Keyboard Replacement: 7 단계, 이미지 1/1
    • Pull up on the metal bar connected to the socket to detach the ribbon cable
결론
다른 10명이 해당 안내서를 완성하였습니다.
Miguel Wong
회원 가입일: 04/15/10
556 평판
안내서 3개 작성하였습니다
Cal Poly, Team 24-35, Regan Spring 2010 Cal Poly, Team 24-35, Regan Spring 2010 회원
CPSU-REGAN-S10S24G35
4 회원들
안내서 4개 작성하였습니다
댓글 한 개
Check out this keyboard at a great price on bcdelectrostore.com
http://www.bcdelectrostore.com/magento/l...
bob harris - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 19
전체 시간: 16,758
