주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Dell Latitude D620 RAM Replacement
필요한 것
    1. Dell Latitude D620 RAM Replacement, Keyboard: 1 단계, 이미지 1개 중 1개
      • Power down the laptop and remove the battery.
      • Open the laptop cover all of the way.
      댓글 쓰기
    2. Dell Latitude D620 RAM Replacement: 2 단계, 이미지 3개 중 1개 Dell Latitude D620 RAM Replacement: 2 단계, 이미지 3개 중 2개 Dell Latitude D620 RAM Replacement: 2 단계, 이미지 3개 중 3개
      • Locate the notch under the cover at the top of the keyboard
      • Using the spudger as a lever, lift the plastic covering
      • Carefully remove the rest of the covering from right to left
      댓글 쓰기
    3. Dell Latitude D620 RAM Replacement: 3 단계, 이미지 1개 중 1개
      • Unscrew the top portion of the keyboard using a #00 screwdriver
      댓글 쓰기
    4. Dell Latitude D620 RAM Replacement: 4 단계, 이미지 1개 중 1개
      • Hold keyboard from the top and gently pull towards the LCD screen to remove the keyboard from the case
      • Don't pull on the keyboard too forcefully because it is attached to the motherboard with a short, thin ribbon cable
      댓글 쓰기
    5. Dell Latitude D620 RAM Replacement: 5 단계, 이미지 2개 중 1개 Dell Latitude D620 RAM Replacement: 5 단계, 이미지 2개 중 2개
      • Once keyboard is out of the case, lay it face-down on the track pad
      댓글 쓰기
    6. Dell Latitude D620 RAM Replacement: 6 단계, 이미지 2개 중 1개 Dell Latitude D620 RAM Replacement: 6 단계, 이미지 2개 중 2개
      • Using a small spudger, pull back on the black bar to release the blue lever
      댓글 쓰기
    7. Dell Latitude D620 RAM Replacement: 7 단계, 이미지 1개 중 1개
      • Pull up on the metal bar connected to the socket to detach the ribbon cable
      댓글 쓰기
    1. Dell Latitude D620 RAM Replacement, RAM: 8 단계, 이미지 2개 중 1개 Dell Latitude D620 RAM Replacement, RAM: 8 단계, 이미지 2개 중 2개
      • With the keyboard removed, you should be able to see ram slot A.
      • Place new ram into the slot making sure it is aligned
      댓글 쓰기
    2. Dell Latitude D620 RAM Replacement: 9 단계, 이미지 1개 중 1개
      • Replace the keyboard by following the previous steps in reverse
      • Close the laptop, and flip it over onto its backside
      댓글 쓰기
    3. Dell Latitude D620 RAM Replacement: 10 단계, 이미지 2개 중 1개 Dell Latitude D620 RAM Replacement: 10 단계, 이미지 2개 중 2개
      • Loosen the screw that holds the RAM cover in place.
      • The screw cannot be fully removed since it is attached to the RAM cover.
      댓글 쓰기
    4. Dell Latitude D620 RAM Replacement: 11 단계, 이미지 2개 중 1개 Dell Latitude D620 RAM Replacement: 11 단계, 이미지 2개 중 2개
      • Insert new ram into slot B
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 26명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Miguel Wong
회원 가입일: 04/15/10
565 평판
안내서 3개를 작성함
Cal Poly, Team 24-35, Regan Spring 2010 Cal Poly, Team 24-35, Regan Spring 2010 회원
CPSU-REGAN-S10S24G35
4 회원들
안내서 8개를 작성함
2가이드 댓글
If you are increasing the amount of RAM installed -> On first power on after installing the RAM, system on boot up will complain about memory size changed, and to reseat the memory. Wait for about 60 - 90 seconds, and you will receive a few additional messages about F1 to continue or F2 for Setup. Go into Setup and verify that the system sees all memory installed. If installing 2 x 2GB DDR2, max possible, 4GB. BIOS setup should report 4GB installed, of which 3.37GB usable.
Michael Erwin - 답글 공유
J’étais inquiet, mais en lisant votre commentaire, me voilà rassuré et j’ai donc suivi vos instructions. Ca fonctionne 2X2 GO …Merci
ppgauchard - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 12
지난 30일: 63
전체 시간: 35,342
