주요 콘텐츠로 건너뛰기
Dell Latitude D630 CMOS Battery Replacement
필요한 것
  1. Dell Latitude D630 CMOS Battery Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Shutdown the computer, detach it from any power source, and make sure the laptop is closed with its latch securely shut.
    • Turn the laptop over so its bottom is facing you.
    • The laptop pictured comes with a palm rest attached to the battery case. This part may not be present on your laptop. Regardless, the steps are exactly the same.
  2. Dell Latitude D630 CMOS Battery Replacement: 2 단계, 이미지 1개 중 1개
    • Using two index fingers, slide the battery latches outward.
    • While still holding the latches out, use your thumbs to slide the battery out towards you.
    • Once the battery is dislodged, you can let go of the latches and remove the battery.
  3. Dell Latitude D630 CMOS Battery Replacement, Keyboard: 3 단계, 이미지 3개 중 1개 Dell Latitude D630 CMOS Battery Replacement, Keyboard: 3 단계, 이미지 3개 중 2개 Dell Latitude D630 CMOS Battery Replacement, Keyboard: 3 단계, 이미지 3개 중 3개
    • With the battery removed, turn the laptop face up and open the lid a complete 180 degrees.
    • Using a plastic opening tool, pry off the corner of the keyboard bezel by undoing the tab.
    • Once you've removed the corner of the bezel, you can use your hands to slowly, but with moderate force, pull the rest of the bezel slightly up and towards you to release the remaining tabs.
  4. Dell Latitude D630 CMOS Battery Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the three 3mm Phillips #0 screws securing the keyboard.
  5. Dell Latitude D630 CMOS Battery Replacement: 5 단계, 이미지 2개 중 1개 Dell Latitude D630 CMOS Battery Replacement: 5 단계, 이미지 2개 중 2개
    • Slowly bring the keyboard up and fold it back onto the touchpad.
    • Be careful not to pull too hard or too far when folding over the keyboard. The keyboard is still connected to the motherboard by a short ribbon cable.
  6. Dell Latitude D630 CMOS Battery Replacement: 6 단계, 이미지 2개 중 1개 Dell Latitude D630 CMOS Battery Replacement: 6 단계, 이미지 2개 중 2개
    • Use a plastic opening tool to unhook the blue latch that secures the keyboard cable.
    • Using the blue tab, pull the keyboard cable connector from its socket on the motherboard.
  7. Dell Latitude D630 CMOS Battery Replacement, CMOS Battery: 7 단계, 이미지 1개 중 1개
    • Remove the connector to the coin using the spudger.
    • Slide the coin battery out of its slot by wiggling its connector with a gentle tug.
    • You may also need to use the spudger to carefully push out the battery from the top of the slot where the yellow square is.
결론
다른 33명이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Jon Amireh
회원 가입일: 01/17/13
1,698 평판
안내서 8개를 작성함
Cal Poly, Team 6-1, Johann Winter 2013 Cal Poly, Team 6-1, Johann Winter 2013 회원
CPSU-JOHANN-W13S6G1
4 회원들
안내서 10개를 작성함
9가이드 댓글
off topic but...in step 4, what is the component plugged into the white cable at the top left hand corner right above that screw?
Josh Henderson - 답글
That looks like the Bluetooth module @Josh Henderson
stm reusables -
I love the easy-to-fix design of these older Dell Latitudes!
Joseph Sctbunio - 답글
Worst CMOS battery placement I have seen. PPD
Lewis Balentine - 답글
it is proving a lot harder to get the battery back in place than to remove it. More photos and guidence would be a helpful.
chefkevin1uk - 답글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 20
지난 30일: 83
전체 시간: 49,896
